Late '70s Panasonic BSR Record Changer/Combo
cb123
Mobile, Al.
The biggest problem with these machines is the type of grease they used from this era turns to an infrangible, super glue like substance. Now, fast forward it a couple of years and the platter becomes tougher to turn than a red hot rim under the load of a locked up brake caliper. But try as they might, whomever owned this thing before broke it loose...broke it loose, that is from its spindle! Soooo, I had to spot weld its twisted rivet back, while keeping the whole thing straight, centered, and aligned. How this was accomplished was with a wooden dowel, which also served to keep the weld out. Its controls only needed some WD-40 ( WHICH MAKES FOR SOME REALLY FANTASTIC CONTROL CLEANER -- MUCH CHEAPER TOO )!!! It also only needed 4 caps replaced. All the day codes on its caps are '78, so, this machine is from '78. The 8-Track player was in pretty good condition, all it needed was some cleaning and lubrication. lastly, it required a 13 volt light bulb for some illumination for its darkened dial. Now, may her little light shine on...and on...and on!
