I converted an Electrolux PN to use with the old metal canisters a while back.
I went with black for the elbow.
I also had a very ugly plastic sheath that had discolored.
I rejuvenated both with a pewter gray Krylon Fusion finish, which came out as a light gray. (It does not show correctly in some pics, but it is a light gray)
I carefully sand the plastic pieces before I spray light coats of the Krylon. My past pieces have held up well, with no chipping.
Krylon mentions no prepping needed, but I feel a light sanding to remove the gloss helps. Also, it comes out better if you spray multiple light coats, waiting a bit for each coat to dry.
