KIRBY VS. DYSON
DysonKing474
Active member
Me and my friend are having a little argument on how dyson or kirby is better, he says kirby i say dyson, now the models have to line up, the DC41 is in alot of ways much better than a kirby sentria or G6 or 7 or ehatever the hell you want. but any dyson is BOSS
REPLY YOUR VOTE, AND SUPPLY WITH AN EXPLANATION
Let's just say, my well-used Kirby Dual Sanitronic 80 is at least 42 years old, I'd like to see a current model Dyson after the same length of time and whether or not it works after living a life of average use...
Somehow, I think the Kirby would be more likely to be still around... :P
Here are the facts...
A Dyson fluffs the dirt. making it appear like more than it really is. We have all seen vacs with bags packed like a bag of sugar with power to spare.
A Dyson does not lift the carpet like a Kirby, Sanitaire, metal Royal, or older Hoover, and it lacks the brushes of a Lindhaus that maintain constant contact with the carpet and spin at 5000rmp.
The Dysons do such a great job because (some) people will keep cleaning with them until they stop seeing dirt being pulled up, and the belts do not stretch. Use a Dyson like most people use their Hoover Elite and it's just another vacuum cleaner.
Both of these vacuums are good.
Dyson would be good if you had to clean a whole house quickly.
Kirby would be good if you needed to do a really thorough job and had a lot of time.
Personally, I would just get a used Sanitaire and a Eureka Mighty Mite. Therefore, you would have 2 lightweight vacuums that don't require much preparation to use. Plus, you could probably get the vacuums for less than $300.
DysonKing
What are the pros of the Dyson in your opinion?
I vote for the kirby. I have used them all my life and like the performance and reliabiliy of the kirby. I have no personal issues with the weight of the kirby or setting up a kirby to preform any cleaning task i desire. I have used varous models of kirbys in homes and in commercial cleaning and found them to be reliable in any setting and will pick up most anything on the floor that will go thru it. Granted many things it will suck up isnt what it was designed for. I have used them to clean up powder from chemical fire extinquishers and drywall dust and still perform well enough to clean efficiently. Many of those same machines are still in use today some over 30 yrs old.
Well firstly, IMHO the whole proposition of challenging a bagged vacuum versus a bagless vacuum is just not fairly represented and the Kirby is like comparing an American sized fridge freezer with a standard, smaller European model in terms of size!
The Kirby is the better performer as Mieles7 notes, and if you have the time to push the vacuum around, then you'll get an effective, better all-around cleaning performance. However the appeal of the Dyson in most cases is that the machines are lighter, easier to push and don't require as much effort despite Kirby uprights that have the self mechanism activated. Also the old mantra stands "there's no dust bags to buy/replace," but you still have to face the dirt no matter what Dyson would have you believe.
Trebor - I disagree- Dyson uprights DO lift carpets but their design doesn't necessitate that they are required to deep clean - the suction power on board in most cases takes care of that already. Dyson uprights lack the superior performance of leaving carpets groomed though.
In my experience, a brush roll that may well have a higher spin or RPM isn't always good for certain carpets and the term "over wear" springs to mind here, when too much vacuuming with a higher-spin brush roll can do carpets more bad than good where general condition is concerned. But then it also factors in the kind of brush roll that is used at the time. I liked the brush roll that Oreck XL uprights have - very bushy, not that rough to the touch and yet leave carpets looking good.
As the owner of a DC-17
Here's what i know:
When using the baird guage it pulls a 1.5 when the filter and assembly is clean after using it on a landing above the litter boxs it would then pull a 0
I've thoroughly vacuums rooms with the dyson then followed behind with multiple vacuums (kirby d80, Hoover Convertible, Fantom Cyclone XT) each time there was a good amount of fine dust and gritty soil in the other machine.
I hate it's brushroll! It is way too stiff i've seen it rip a line out of commercial pile carpeting and i don't use it often because i feel like i may be causing damage to the carpet.
The dyson is an interesting machine but, i feel that, it doesn't have the airflow or agitation to properly deep clean.
In terms of carpet cleaning the Kirby is definitely the better performer you cannot beat the lifting sweeping and beating of carpet to dislodge deep down grit
Yep, I think it is widely known that a Dyson does not pick up fine dirt, meaning over time your carpets will be ruined as you walk over them and the fine dirt acts like sandpaper.
well the damn dyson people decided to go with the helix brushroll system instead of a standard cylindrical one.
So Dyson finally copied what has been working for Lindhaus for over 20 yrs?
 Just one thing, every one goes on how a Kirby is the only vacuum to be able to suck the sand up thru the carpet pile. Last week I had 4 carpets at my house replaced. They have been down for 10 years, gone thru 6 building renovations ( opur house is brick and concreate not wood)  two of the rooms haveing most of there outer facing walls removed to add bathrooms.
There was nothing much wrong with them but they were a looped pile wool carpet and I felt like a thick plush cutpile in a new colour so we changed them.
The carpet guy wanted to know what vacuum we used as he had never in his life seen so little dust under a 10 year old carpet.
There wasn't even enough to sweep up. These carpets have been vacuumed by dysons for the last 10 years, at first a dc04 a green and grey non clutch model, then a dc07 with clutch but fitted with the USA soulplate and brushbar, then it jumped from dc14, dc28, dc27 , dc25 , dc15( i chop and changed between these on a daily basis )  and currently a dc40. When I started selling dysons I used many models as I tested them and tried them out.
Im not saying a kirby is not good but a dyson is not as bad as many of you say it is, it could never be they spend to much on research and development testing and testing and seeing what works best on getting dirt out of a carpet. Just because its not metal and doesn't weigh a ton does not mean its not a good vacuum.
Gareth
Well anyway, some people live like pigs, so I think it doesn't matter what cleaner you buy as the cleaning regime of the user will account for how clean the home and the carpet is. Hopefully they will be clean enough to be healthy but still have a sufficiently busy lifestyle not to worry too much about it.
