vacfanatic
Anyone else have this issue with any of their Kirbys? I just traded in a used Sentria which had a metal base pan, for a new 2009 version with the polymer base pan. The new Sentria skips pretty bad on my carpets if I move the cleaner too fast. The old Sentria didn't seem to do this, granted it was a tad bit heavier with the metal base pan and did not have a Hepa Cloth bag in it. (I had not been using the Hepa Cloth bags as they are a bit more pricey and I had a load of the Micron Magic Paper Hepa bags around).
I did a test to see what the issue is, and it's just the type of carpet I have apparently with the increased performance of the Sentria vs the Diamond Edition I had.
It seems that with the increased airflow with the Hepa Cloth bag / Sentria setup, the skiping and hop is pretty annoying to say the least
. I did cut the bag collar on my older Micron Magic Hepa Paper bags that I used on the Diamond and the problem nearly went away on the new Sentria, but there was still a tiny bit of the hop here and there. The Diamond used to do it every now and again though.
The "solution" I'm going to have to stick with for now is switching to these Hepa Paper bags, will reduce performance. Not sure by how much tho... Sigh.
Guess I'll just have to rip out this 2 year old carpet and get something Kirby Compatible?
Fat chance of that happening!
I think the transmission on this Sentria is just really touchy - increased nozzle suction locks cleaner tighter to carpet, transmission gives more push, nozzle gives and cleaner moves forward, transmission lets off a bit, then nozzle locks again, causing the cleaner to jerk. Repeat rapidly, and you get the idea. Grrr....
Solution? Please?
Pic of my type of carpet below... and Max when he was "new in box".
Andrew
Solution? Please?
Andrew
