R rodknock95 Well-known member Joined Mar 16, 2019 Messages 146 Location Salem, Missouri May 26, 2019 #2 Are there other areas that the serial number would be if the label on the bottom of the machine is damaged, like on a Classic or Omega?
kirbyclassiciii Well-known member Platinum Member Joined Mar 18, 2009 Messages 5,346 Location Milwaukie, Oregon May 26, 2019 #3 rodknock95 Blaze, No, unless you check the armature and field coil. The Classic III moved the serial number from the nameplate to the fan case. ~Ben
