electrolux~137
- Joined
- Jul 23, 2009
- Messages
- 2,950
What's y'alls opinion on the wider front "Classic-style" wheels that were (are?) provided with Kirby's rebuild trim kits?
Did people really have a big problem with their Kirbys tipping to and fro or being unstable because of the narrow wheels? Granted, they are set in kinda far from the nozzle, but I've never had a problem with that. I could see the point in the wider wheels when the Classic, with its huge nozzle, came out. But I've never seen them to make any significant difference with older machines.
The way the wider wheels attached was that they came with a special screw with an extension the length of a standard wheel. That way, you could screw the wide wheel into the standard axle.
Something I've done that I like better than using the wide wheels is to put two standard front wheels on each front axle, using the extender-screws. That looks more "original" than the new wheels and accomplishes the same thing, although I do still like the more streamlined appearance of the narrow wheels.
