Kirby Nozzle Gasket Adhesive
briguy
Wichita, Kansas
Hi all, what's the recommended adhesive to use on a Kirby nozzle gasket? Is it rubber cement? I recently acquired this Heritage 2 that needed a new fan & good cleaning & tune up. It's back in action but needs the gasket adhered better.
Hey
If you are adhering gasket id use clear silicone or super glue. Basically anything that adheres metal and rubber than is clear. The motor housing would need good gasket but most would suffice.
I wouldn't use super glue. It gets hard and crusty and might make an imperfect seal. Granted, it's not perfect to begin with.
A couple tiny dabs of any kind of silicone behind it. No need to smear, as I'm assuming you just want the gasket to stay put, and not to improve the seal, right?
Emblem or weatherstrip adhesive would work fine as well. Kind of whatever you have on hand. I don't think rubber cement would hold it for very long.
The adhesive that Kirby uses is a brown rubber cement, it used to be made by 3M, I forgot the Kirby part number, it was something like T110, it has been a while since I ordered it from them.
Hey
Uh dont use the 3m adhesive its to thick and has color to it. Its great if your using it as a gasket but to hold a gasket on its to thick.
Clear silicone. There is a product called goop glue. The people who make sjoe goo make it. Ive used it on quite a few things.
