Kirby model 2C questions
jmathes1991
Bourbonnais IL
Im at a loss at the moment. Ive called dealers vac shops and checked the internet. I just bought a decently nice model 2c but the fans cracked and i cant find it anywhere.
Are you trying to find another fan for it?
Or are you just asking for help for replacing the fan?
If you're trying to find a fan
Kirby makes new polymer fans that fit inside old machines like this one. If you want an original aluminum fan, there might be a collector who has one.
I mean either option is a go for me. When i talked to kirby and the few shops i called. They said there was no specific part for that machine and they couldnt go back that far in there system.
Kirby 2c fan
That fan is unique to the C series, not other newer fans are even close. If it is a 8 blade fan with a large chip out of one blade, sometimes you can brake off the same amount of an opposing blade with a pair of wire cutters. This will get it close to being back in balance.
The 2C uses the same fan as the C, it's a 6 blade fan (part number S1187). It is smaller that the 500 series so the newer fans will not work.
