Kirby Heritage II, Carpet Lines
bagintheback
Platinum Member
Flagstaff, Arizona
I've had this Kirby Heritage II for some time now, and I've always noticed it doesn't make lines on the carpet like EVERY OTHER vacuum does on my carpet. I have very short pile carpet. I bought it off ebay, so I don't know if the belt is new. Is this normal or do I need a new brush roll or belt?
I would say check the tension of the belt, if it is sufficient then check the position of the brushroll. The bristles may need to be adjusted so they come down closer to the surface of the carpet....
try...
adjusting the brushroll to a lower setting, so the bristles meet the carpet a little more. It is probably still on "one". But if it is on "three" then the brushroll needs to be replaced because the bristles are to short.
Yea. Geeze I have not had one for a long time!
Let someone else help ya. I cant remember. Its a screw adjustment. I forgot how to do it.
the yellow line means it is NOT a real kirby belt, but a made to fit. Change the belt when you adjust the brush roll.
in my opinion a good vac does NOT leave carpet lines, lol.
I wish my legend II made carpet lines :( I would adjust the brushroll more but then the carpet may not get sucked into the nozzle? same with my tradition.
