Kirby G6 Scuff Plate Screw
waynec
I wondered does anyone know the thread and size of the little torx headed scuff plate screw on the back of the Kirby G6 just above the N-D lever...?
Internet suppliers want £12 delivery for the original part from the USA for a £1 item... and I can't find one in the UK or the spec listed anywhere.
and I'm not too bothered about originality.
I recently bought two of them on eBay from a seller called kirbyfans for $1.35 plus $2.63 shipping for a total of $3.98 USD. I have no idea what he would charge for overseas shipping, but he was a pretty reasonable individual to deal with. That said, I also found a cheaper alternative.
I don't know anything about the structure of UK light switches and electrical outlets, but I discovered that an anchor screw (the one that holds a wire in place) from the U.S. version of either of those things is a perfect replacement for the lower scuff plate screw—the right length, threads and everything except it has a brass finish. I discovered this quite by accident when I was cleaning out the mini emptor on one of my G6's and one of those screws fell out. How it got there, I haven't a clue but it turned out to be a godsend when it fit like the proverbial glove. So my G5 has that screw and the G6's both have the OEM screws I had bought previously. I just love that I found the screw inside a Kirby G6, of all places.
I hope my ramblings were helpful.
Thanks Human.
UK electrical fittings have gone metric whereas I don't suppose US Kirby's or fitting will have.
a bit of research on the internet suggest that the screws you're describing as US anchor screws are 8/32
#8 screw with 32 threads to the inch
or maybe 6/32
UK light fittings use m3.5 to hold the plate to the wall but I'm not sure of the anchor screw spec. Think it used to be a UNF or BA thread but imagine it's gone metric nowadays. The trouble with Google now is you get flooded with all the rubbish answers and the info you need is hidden away.
I'll try experimenting with the other screws on the Kirby and if I can identify it fully, I'll let you know.
I don't know whether there are big hardware/home improvement stores in the UK like Lowe's and Home Depot here in the U.S., but it might be that you can go and look at their display of screws, buy a few likely candidates, and return the ones that don't work.
I actually did this last evening. I replaced the brush roll in the power nozzle for my Electrolux 1205 and found that one of the bottom plate screws was missing. I took one of the remaining screws to Home Depot and got the closest thing they had. Even though the OEM screw has some unique characteristics like a little point at the bottom to help center it up in the hole and threads only a third of the way up the shaft, the generic machine screws I bought (4-pack for $1.25) worked perfectly.
Yes, we have big stores such as B&Q and Homebase and dozens of small independent hardware stores that would provide something similar.
As an ex-metrologist, I could even measure the diameter, threads per inch, and thread profile, and order one up as replacement that meats the same spec... but the problem here is I don't have the original or another remaining screw...
So it gets a bit trickier to measure the internal threads, so if we don't want to destroy the sample, we have to measure the internal diameter using a plug gauge, then we have to make a mould of the thread profile using plaster of paris or modelling clay and then use a profile-projector (shadow -graph or optical comparator) to determine the profile angle, thread pitch and measure the thread height, then add twice the height to the inside diameter to get the outside diameter.
Or I could just do as I usually do these days and try lots of odd screws until I find one that fits...
