Kirby G4 Transmission
Jakesvacs
Hey,
In neutral my kirby g4 clicks when being moved back and forth? What causes this and is it broken?
Check the Cam Bracket...
Sounds to me like the Cam Bracket needs to be replaced. The Cam Bracket is the little part that pushes the gears apart when the peddle goes from Off to On. It wares down over time. If you take the transmission out for the base unit, you unscrew the control peddle and as you remove the peddle the Cam Bracket is on the peddle. It sits loosely, so it is easy to replace. You can get one on eBay fairly easily.
Justin
Thank you very much! Know who to ask kirby questions about now! I thought it would be something much more majour, but seams easy to replace!
Thanks again,
Jake
