mariotron Well-known member Joined Sep 28, 2016 Messages 104 Location Texas Mar 7, 2018 #2 I bought a G4 shampooer a while back but a newer model suds screen came with it... Is there anyway around this or do I need to buy a new one?
lesinutah Well-known member Joined Aug 26, 2017 Messages 5,481 Location Utah Mar 7, 2018 #3 Hey It should work on any g series. The exception maybe avalir or sentria 2. But i think this is universal for g series just different color. Les
mariotron Well-known member Joined Sep 28, 2016 Messages 104 Location Texas Mar 8, 2018 #4 @lesinutah I must be doing something wrong. The screen seems to be the same diameter as piece where I attach it do I need to heat up the screen a bit to fit over it or just put in the hose?
crazykirbydude Well-known member Joined Jan 28, 2017 Messages 872 Location Lexington, KY Mar 8, 2018 #5 Just cut a bit of old T shirt and put it over the part where the screen is supposed to go and put the hose on over the T shirt piece. Worked for me.
mariotron Well-known member Joined Sep 28, 2016 Messages 104 Location Texas Mar 8, 2018 #6 crazykirbydude Thanks, That worked great! I ordered the right screen but I needed to use it right away. Thanks again.
lesinutah Well-known member Joined Aug 26, 2017 Messages 5,481 Location Utah Mar 8, 2018 #7 Hey I'm told panyhose also works. Les
crazykirbydude Well-known member Joined Jan 28, 2017 Messages 872 Location Lexington, KY Mar 8, 2018 #8 No problem! I was in a similar situation in which the screen part had separated from the plastic plug part.
