vaclover
Will a kirby legends fan fit my kirby model 508?my model 508 only have 6 blades and is made of metal. If i can put on the newer blade it would be easier to replace if something happens. And does somebody know the actual wattage of a kirby model 508?if im correct 3 amps 110 volts will be 330 watts, but mine is 230 volts so 3 amps will be 690 watts?or does the amps also change with the voltage?im not sure how you guys feel about it but im using some of my vintage vacs once in a while?always cleaning it before storing them again.
