Kirby Dual Sanatronic 80
vacmaster0000
Hi. I have never created a thread before. But here we go. I have a Kirby D80. And it viberates whenever the rollerbrush is engaged. It sounds fine. Except for the horrible buzzing noise! It dosent do it when I have the belt off. Also what can I use to shine it and clean the bag? Thanks! All answers all greatly appreiated! :)
the bag,
you can wash in the washing machine on GENTLE with a little detergent.i did it with mine and now it smeels awesome!idk about the brushroll and shineing.good luck!
and welcome to the club!
After removing the bag from the emptor, turn it inside out and give it a good brushing/vacuuming first so you don't gunk up your washer.  Use mild detergent and warm water, not hot.  Hang the bag to dry, don't put it in the dryer.
The brushroll may be imbalanced (the ends not adjusted evenly) or it may just be shot.  The new replacement brushrolls with ball bearings are much better in my opinion, and you can even get them with 4 brush strips instead of just 2 which will greatly improve cleaning performance as well.
Machine buffing the metal will give the best results, particularly if there are deeper gouges/scratches.  I, and many others here have done it "the hard way" with pretty good success using metal polish and #0000 steel wool.  It takes a lot of patience, persistence and strong hands, but once that metal is gleeming again it's well worth the effort.
Btw, I love my D80 too!
Neil
