Lesinutah
Les,
On all Super-Sweep models from serial no. 110001 (the army green/D80 trim version), yes, they used a three-wire brass ground plate (1110) which is simply mounted on top of the foot switch using the same two mounting screws (1125).
In original production, the field coil used on these commercial cleaners came with two terminal clips that were soldered to the yellow and red wires that connected to the top and bottom carbon brush assemblies (respectively) on the motor housing. But in replacement, the field coil (which is exactly the same as for models D50 and D80) does not have these; therefore, if confronted with replacement, you must also order two terminal clips, which in this case must be soldered to the yellow and red wires: the field coils on the pre-1979 models (serial no. 210000 and lower) will have the same style terminal clips as used on Kirby models 519 to D80 (part no. 104559), whereas those built 1979 and later (serial no. 210001 and up) use the same style of terminal clips as found on models Classic 1CR to Heritage II (part no. 104569).
Yes, I do believe I can fix the schematic part for the green (ground) wire.
~Ben[this post was last edited: 6/15/2020-13:16]
