Kirby Classic III -- All Finished!!!
eurekastar
Amarillo, Texas
Well almost . . . I had the day off, so I spent the day disassembling the vacuum, thoroughly washing everything, and polishing the castings. I'll reassemble everything tomorrow and post a photo.
I ended up using the original handle fork. I thought I would be clever and harvest one from a Heritage series vacuum so the cord winder would be on the left, opposite the bag. I cleaned and polished the handle and got ready to assemble it when I discovered that the screw hole for the handle back is in a different place. I thought about ordering a handle back for a Legend II since it's the same color, but I really don't want to wait for it! So I'll just keep it all original.
The fan was a *&^%#%@&@* to get off! But nothing that a vice gripe and a little muscle can't handle! The rug plate needs a new gasket, so that's on order. I'll just use the rug plate from my Tradition until the new gasket arrives.
And for comparison . . .
This is what it looked like when I got it. It had a Classic Omega handle on it. The bag had a tear, the fan case gasket was missing, and the old aluminum fan was all busted up. No wonder it wasn't picking up anything!
Bonus
When I unzipped the scraper pocket, I found these things -- an old bottle of Kirby Odorific and a couple of plastic things that look like they are stuffed with cotton. I'm guessing that you'd impregnate those little things with Odorific and put them in the pocket.
Nice buffing
I ordered some green and brown buffing compound from my kirby dealer to use with my 1hp sears bench buffer. I was impressed with the way my G5 came out it looks like new.
With Satellite Service . . .
I decided to go ahead and assemble the belt lifter and put it on the nozzle. This belt lifter assembles in a completely different way than the Heritage and G series belt lifters. And like a dork, I put the hook on upside down and then assembled everything to the nozzle before I realized I had done it wrong. Luckily the adhesive on the label hadn't cured, so I was able to peel it off without messing it up. There are two retaining clips, one on the outside under the label, and the other one on the underside.
And here she is . . .
all done! I ended up doing more polishing this morning on the Sani-Emtor. It was late last night when I polished it, so I wasn't paying attention to detail.
Each machine I've rebuilt has been a learning experience. The one thing I can't quite figure out is how to install this little clip on the headlight hinge pin. It puts tension on the headlight assembly so it stays up. I got frustrated and quite fooling with it. This machine has a new bag, nozzle bumper, headlight trim, handle, handle label, four row brush roll, front and rear bearings, motor brushes, motor brush caps, impeller (fan), Sani-Emptor gasket, and fan case gasket. I had to order a new gasket for the rug plate too. But it's not here yet. So for now, this machine is borrowing the rug plate from my Kirby Tradition.
Those Are Beautiful Machines
One of my all time favorites. Bought mine new in '76 and sent it back to the factory for a rebuild in the around 1997. About time for another beauty treatment. You have inspired me.
Beautiful job Bill!! Looks like they have been to Kirby for a complete rebuild!
Richard
One thing I'm doing is using 4" wheels in addition to the larger 6" wheels. It's easier to get into some places with the smaller wheel. The G series is also good to learn out because they are fairly straightforward don't have all the nooks and crannies that the older machines have.
Thanks Vernon
I appreciate all your tips since I get many kirby's in Tucson I can get lot of practice with my Craftsman bench buffer.On utube there is someone using a ryobi angle grinder with polishing wheels also buffing metal. The polishing kit is $10.00 at home depot wouldn't mind giving this a shot for the hard to buff areas.
Richard Groski
