Kirby Classic III -- All Finished!!!
Polishing a Kirby
I made a lot of mistakes learning to polish and still have a lot to learn. For instance, I had to learn that there is no substitute for the polish that Kirby sells to its distributors. Second, one my of early mistakes was not being careful about never mixing different compounds on the same wheel. I think that's especially true for the color finish. It makes complete sense to me now, but it didn't at first. Another thing I'm learning is to do the color finish one day and then inspecting it the next day. I think sometimes I've worked so long on something that I get a little "blind" to what it needs to look like. By looking at it the next day, I can easily see areas that need work. I've also used polishing wheels and bits for my drill, but the results haven't very good. So I will still resort the good old fashioned steel wool during the cutting polish in order to get to some awkward spots. A friend also shared a technique of using sand paper to sand out heavy scratches before going to the polishing wheel. I haven't done it yet, but he begins with a coarse grit, then wet sands with successively finer grits, until he ends up with a very fine grit. Then he takes it the wheel. But he warns about not sanding too much that the metal is compromised.
It's Official!
I think I really like the shakeout bag! Why? Well, I get this odd thrill out of examining the debris! Is that wrong? I think that's why I like my Compact/Tristar vacuums. Like a Kirby, the engineering is simple and straightforward AND they both allow you to easily examine what you just vacuumed. This is from a whirl around three rooms since using the Classic III for the first time yesterday. I really like this vacuum! DISCLAIMER: This photo is not a commentary on the literary section of USA Today.
More Results
I came home today at lunch and vacuumed with the Kirby Classic III. This the result of just three rooms after NOT vacuuming for two days with two dogs and four teenagers and their friends going in and out of the house. (I have no hair that contributed to that pile.)
Me too
This and a couple other recent Classic III threads have enthused me to get mine out and use it again as well and I agree about the shake out bag. For some reason I recalled that emptying it spewed a cloud of dust all over the room, but if you shake it first with the Sani Pocket and then gently open the emptor, there is no cloud.
Emptying the Bag
I don't have an instruction manual for the Classic III, but my Tradition manual says to lower the nozzle all the down to the last notch, close the suction relief vent on the nozzle, unhook the bag, turn the vacuum on briefly to inflate the bag, then turn it off. As the bag deflates, shake it vigorously from the top. That loosens dust and debris, causing it to fall into the Sani-Emtor. It works well too.
CIII manual
What you just described sounds very familiar. I don't have the CIII manual but it's posted just a few threads below this one on:
Thread Number: 9498
Kirby Classic III Model 2 CB
