vacuumwars
Ok so its my second day testing the Avalir 2, which is my first Kirby vacuum.
I bought it used so there is a possibility of wear or other issues, but other than a slightly lower CFM numbers (129 instead of 137) than other Kirby numbers I have seen everything seems to be in perfect working order.
I want to like the Avalir 2. Its really solid and fun, I even like just looking at it, but I am wondering how much my experience so far is due to my lack of experience with Kirby vacs.
Here are some things I have noticed:
1. It is good with hard floors but you really have to constantly play around with the height adjustment based on what you encounter. Too low and it pushes it around, too high and it wont pick it up, and because the hose is a lot of work to attach, you find yourself having to change height quite a bit.
2. On hard floors you simply cannot have the brush spinning or it will shoot debris everywhere, I am assuming this is a rookie mistake.
3. because of the superb airflow and agitation it is great with deep cleaning carpets, I would say that this is why someone should buy a Kirby, though it kind of has the same problem as hard floors with needing the height adjustment. You basically have to go over larger debris fields once with the height up and once with it down.
4. I like it in canister mode with the combo tool? Im not sure what it is called but it does decently with fine debris on carpets and really good with hard floors. Though I found that its really bad with pet hair clumps on carpet, though good on hard floors.
5. In my crevice pickup test where I have 2 crevice sizes 1/8" and 1/4" filled with coffee rounds or sand It didnt do as good as I thought it would considering the airflow is much higher than anything else I have tested. It was confusing, I mean it did very good, but it did leave some debris with the sand version and the coffee wasnt a perfect run either. The Shark Apex, Dyson Ball Animal 2, Dyson V10 and V8 all did slightly better, I am assuming that it has something to do with shape and style of the floor head, which I have seen plays a role in that test before.
I havent tested any of the other attachments yet (shampooer etc) I will probably start tomorrow with that.
So I guess I am asking if my experience is on par with other Kirby owners and Kirby lovers. I guess I have assumed that it is the greatest vacuum ever, and maybe I had my hopes a little too high. I also dont want to put out any kind of video on it until I am sure I am doing everything right and truly understand what I am doing. SO any help or thoughts would help.
