Kirby 561 Resto
biggreen
Boston,Ma.
Newby here , Just got a Kirby 561. Its complete but needs some love . Id like to restore and use it . Whats my best option for a Bag ? Do I buy the black shakout I see available or do I search for an OEM bag ? or is there an upgrade that may make more user friendly. Wheres the best place to buy parts? Id like to avoid cheap counterfeits. Cant wait to get started !! Thanks
kirby bag
the black ones you see on ebay are cheap & thin. do not buy these. i speak from experience. ask around & you can find an original bag no doubt or one that has the good thick cloth from the kirby company.
OEM Bags
The black bags seen on Ebay and elsewhere are, in fact, made by Kirby. For whatever reason, Kiby does not put a manufacturer's marque on them. Order a replacement from a Kirby Service Center and that's what you'll get. Pictured is a Model 517 restoration I did with one of the bags.
Also, I've washed many used bags with good results when they weren't too worn. I turn them inside out and vacuum them to remove as much debris as I can. Then I rinse them in cold water. After that, I wash them in cold water on the gentle cycle using woolite and hand them out to dry.
By the way
The Kirby in my avatar is an all original Model 560 that I restored a few years ago. The 560 and 561 are almost identical. The only exception is a slight difference in the belt lifter.
561 was the last year for the open top shake out bag current Kirby part #190062.
The next year model 562 used the bag with the Sani-pocket (where you could hide your snacks while vacuuming).
If you do go on ebay Kirbyneeds (located in Utah) is a Kirby dealer and has the bags in his ebay store Kirbyfans.
I just go through my friendly local Kirby repair shop they can order them from Kirby.
If you need a new belt or brush roll, it takes the older softer belt, don't use the newer knurled belt.
Belt #159056
Brush roll #1525
are you wanting to just clean up what you have, or restore it to all original? that makes a GIANT difference where you obtain parts from.
Will Hemb
Hi Will,
I want to restore it, but I am going to use it as well. At this point I have begun disassembly and I plan to polish all aluminium and reassemble with as many OEM parts as I can find. I would settle for a regular bag but would at some point like to find the correct one that I could set aside. Thanks for your interest. Ken
Painting Trim
Unfortunately, Kirby no longer sells red trim. However, you can use plastic/vinyl paint on it with every good results. It's also very durable. If you'd like to know more about how to do it, please let me know.
Eurekastar, Thanks for the info on the rivets, Id like to hear about the bumper painting process. the Picture of your Kirby is certainly a benchmark. Today I will be completing the disassembly and begin the wet sanding/ polishing of the aluminium.Ive done my share of this as Ive restored a few motorcycles. Thanks, Ken
The front bearing comes already attached to its mounting plate. That plate his held on by four screws. You can gain access to the screws once you have the fan off. The rear bearing requires a special bearing puller in order to get the bearing off the armature. Those pullers are made by Kirby. The puller is definitely worth the investment if you plan to service a Kirby yourself. They all will need the same tool for the rear bearing. When you replace the rear bearing, you'll see something in there called a finger spring. You can replace it too or simply "respring" it by bending the fingers back out. Hope this helps! I always have a lot of fun rebuilding Kirby vacuums.
http://www.ebay.com/itm/Bearing-Pul...181389919165?pt=US_Vacuum&hash=item2a3bae83bd
http://www.ebay.com/itm/Kirby-516-1...181320163723?pt=US_Vacuum&hash=item2a3786218b
Correct Bags
Hey everyone, we keep forgetting to support Chicago Mike. He has replicated original bags for the Kirby 500 series. I haven't had a chance to use one yet, but my guess is that they're pretty good. They're on sale on Ebay. Also black wheels for pre-1956 models. I think we need to promote his efforts every chance we get!
Replicating old parts
Would it be possible to replicate the red trim so it would not have to be painted with the S.E M. spray paint? How easy would it be?
Maybe
Mike will see this and respond. If not, message me and I will give you his address or write him on your behalf.
Mint original bag.
I lucked out several years ago and came across this absolutely mint condition original 560 bag.
My 2 year old who is absolutely obsessed with my obsession. lol
