Is this a good coffee maker
Thank you
Yeah I have a cuisinart coffee maker that I like without the grinder but I saw one of these at my favorite picking place for $5.00 and I was woundering if anyone had one and if it is prone to clog ups.I had a earlier model that would clog with grounds. I do like cuisinart coffee makers along with my keurig.I had several percolators but sold then before the move to Delaware.
I bought one of those a couple of years ago.. After a few uses the grinder started clogging up and then failed so I returned it for a refund. They had a different version before that one with a spin type grinder which worked better but even that one only last maybe 3 years before it conked out. I've given up on them.
I've got an old, basic Black & Decker that I paid about $17 for at Walmart around 2004. It was the cheapest thing they had with a clock on it for automatic brewing. It makes decent coffee and has been totally dependable. My only complaint is the plastic body is white instead of black, so it's now permanently stained. It's ugly but it refuses to die.
I refuse to take the plunge into K-cups because they're overpriced (both the machines and the cups) and environmentally irresponsible with the amount of solid waste they generate.
Cuisinart has been around for a while as coffee maker brand but it is considered to be average. The one that I had lasted 2 years, which was OK.
I don't drink coffee, but I find simpler is better.
My mom had a cheap Proctor Silex and said she wanted a new coffeemaker, so I bought her a Kenmore programmable for Christmas in 2007. It was the worst coffeemaker ever, and she was always complaining about it. The springs on the lid broke, it was impossible to clean the tank and one day the plastic ring around the burner cracked, making a loud POP! Sears actually recalled it for fire hazard issues so she exchanged it for another, but it was nearly as bad. Finally it just started spewing steam everywhere when she used it.
She got her Proctor Silex back out and started using that until it leaked. Then she bought a new Proctor Silex, but something went wrong with that soon after. (I think her water messes them up mostly). So she bought a basic Mr. Coffee, but the little piece on the bottom that stops the flow when the pot is removed broke off so she had to use it without the lid on the pot. She tried to order a new part, but the shipping cost was more than the whole machine. LOL
Finally I looked at Walmart one day and found the cheapest one they sold, a Rival and knew it was what she was looking for. It was the only one I could find anywhere that still has a pull-out filter basket instead of everything under the lid, which she said made a mess.
She has been happy with this less than $9 wonder, and it is holding up fine. If it breaks, she can get a new one for cheap.
It's sad that the older ones lasted for decades, not just a few years at most.
"<a name="start_28025.318620"></a>I never really drink the stuff.  If I make a cup or two,  I use a French press!"
You are very lucky John, a caffeine addiction is not pleasant!!
I am definitely one of those "beasts".
Before my first coffee I literally appear drunk as I am slurring my words and cannot walk straight.  It is only after the first cup that I can compose myself.
I laugh, because 4 cups is what I consume in the first couple of hours of waking up!!
On the plus side, coffee is very good for productivity when you drink enough to get a "buzz", so it is a case of "live by the sword die by the sword" I guess.
"I use 2 lbs of beans a month by myself."
I'm about the same, although I (ashamedly) buy coffee grounds... I KNOW, I KNOW!
I grind with my KitchenAid A-9 Coffee mill and like the Sunbeam Vacuum Coffeemaster.
Something about useing a vacuum coffee pot just makes it better.
Simpler is better
When I have coffee I grind it with my bodum burr grinder and brew with my moka pot. Ya get a good strong cup'o joe and everything comes apart to clean by unscrewing the top from the bottom.
