Deleted member 1090
- Joined
- Aug 18, 2012
- Messages
- 1,253
Electrolux Model ZB 86 needs a new motor i think .
Bearing and carbon brush looks good im no expert tho , but the THING THAT WORRIES ME is the wiring coil aka flied if you will a wire seems to be loose i attach it on the carbon brush but not sure if i should just replace the field coil or the whole motor ?Seem to run well before i took apart last year but had low suction due to a bad gasket. Now id like to get it up and runnign whit good wires to be on the safe side of things you know ?
Pic 3 and 4 motor wires loose
