Metaphys Uzu Cyclone Rechargeable Vacuum: Redefining vacumin
Uzu is a cordless vacuum cleaner that makes it very easy to overcome one’s inhibitions against cleaning. Its characteristic appearance was inspired by the conception of a vacuum cleaner that can proudly be presented. One movement is enough to get it started: just lift the handle. The Uzu is not stored in a cabinet as customary, thus it is always ready to hand and invites you to use it.
Here is a product that can actually make vacuuming fun! Gone are the days when gadgets meant for boring jobs looked boring as well. Sleek, stylish gadgets rule the day. They are fit to be shown off, instead of being stashed right into the corner of the cupboard once its use was over.
And designer, Chiaki Murata’s The Metaphys Uzu Cyclone Rechargeable Vacuum is surely The product for today’s household. It sounds like the user’s dream-come-true. It’s a convenient size (W8.5xH23.6xD14 inches ) and light enough (10 lbs.) to be carried around easily.
Moreover, it has this unique facility of being rechargeable. As a result of this, the entire device doesn’t need to be dragged around, cords and all, when something spills somewhere. Simply unplugging the UZU from the wall would easily transform it. This considerably lessens the laborious steps which have so far been associated with vacuuming.
It is available at Compact Impact for $398. Take your pick from black, white and orange.
If you're anything like us, the act of vacuuming is a sad activity indeed -- if the noise doesn't get you, then it's the tiresome act of having to go through those dark corners of the home you'd rather just leave alone. Thank goodness then for Metaphys' Cyclone Cleaner, which adds a touch of panache and smart functionality to an otherwise dull product category. Brainchild of Osaka-based designer Chiaki Murata, Metaphys has been wowing us with pretty much everything it's produced -- from the HONO electrical candle lights, which mimics the behavior of a real candle, to the Factory series of indoor-gardening accessories -- and the Cyclone Cleaner does not disappoint. The image here doesn't do it justice, because the act of opening up the folded vacuum immediately transforms it into a regular-size appliance, with the base carefully balancing the extended nozzle. It's a smart response to the need for compactness in small Japanese homes while, at the same time, offering for a larger, easy-to-use size. Hitting stores in mid-June, it will be available in three colors (white, black and orange). Alongside all of Metaphys' stunning designs, it can be viewed at their new Tokyo showroom/office (03-3446-8648), located at the Tokyo Design Center (5-25-19 Higashi-Gotanda, Shinagawa-ku).
http://metaphys.jp/product/en/
