I want to buy a hardwood floor polisher but need advice
Ok so this really seems like the way to go. One last question what is the difference between the B series polishers is the 7 not as good as the 8, is the 9 better than all of them? Or is it just colors?
Electrolux 3 brush polishers
There were also B-3--B-6 3 brush polishers from 30s to 50s but the B-7 and later are better and still a great choice for hard floors.
As with many polishers some Elux have added weights for proper pressure on brushes.
Brushes--I think the B-8 brush will fit the B-7 but the B-7 will not fit the B-8.The B-9 changed to a 'twist off'brush that should NOT be used on B-8 and B-8 brush should NOT be used on B-9.Pads are same except for some B-7s with different brush holders.
B-7--Was hard floor only machine with T shaped handle and 2 speed switch.Some had small metal tank for liquid wax.
B-8--Added shampoo parts for the increasingly popular wall to wall carpet as well as continuing as a great polisher.Was 1 speed.Some had removable cord as on Mo L vac.
B-9--Added more plastic parts,cordwinder and trigger on handle for shampoo tank.Polishing brushes were often optional as most customers used as shampooers.
I finally found a B8 on ebay that didn't look worn out, and it actually matches my Electrolux canister. The only thing is the owner decided to break up all the parts, I emailed her and she said she would consider taking an offer on everything, but she separated everything to "maximize her profits". The machine is one of the blue ones,thats one auction, then she has the following in separate auctions she has the hard wood brushes, carpet brushes, brown pads (I hear you can apply paste wax with them), green pads, bumper, soap dispenser, brush holder platform, and some kind of metal plate that attaches to the machine. What do you guys think would be a fair price to offer for the machine? If I were to pay for all her auctions Id be in for over $300 which compared to other machines is almost triple, but most machines dont come with more than one set of brushes.
B-8
B-8 is a great machine and the blue would be the first of about 1970.
You might want to consider that if you will not shampoo rugs(which it can also do well)you would not need the soft shampoo brushes,soap dispenser(tank),or the "metal plate" if is actually blue plastic with a lock button in the middle(suds shield).The 'bumper' is probably the splash guard that prevents suds or cleaning solution from splashing on baseboards,etc.
An Elux polisher can often be found in 'low mileage'condition as they usually were used for spring cleaning type jobs and even less frequently as 'miracle'waxes,no wax floors and spray can shampoo were introduced and promoted.
Ok, I'm looking at one on eBay now, it's Gold so it's a later one. It's still a B8 though is there any draw backs to this model? I wish someone on here had one for sale.
B-8
As I said above they are great machines.The gold started in 1974 for the 50th anniversary.
If you are looking at the one from isoldit it looks VERY good and complete.The owners manual is a nice bonus.You would only need to add soft polishing pads.The suds shield(ONLY for use with soft brushes) has minor damage from being used with hard floor brushes that would not be a problem if push lock button is good.The paper tag on cord since new would confirm a 'low mileage' Electrolux.The handle can be unlatched and folded forward for storage/carrying.
It was that one and I did buy it, the other ones on there looked pretty worn. The woman I didn't buy from, had these pads for sale are they worth buying
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/183645453569
I've been trying to read as much as I can on the site, and I read somewhere the brown pads are for applying the paste wax is that true? I'm guessing I should buy the lambs wool for polishing it off though right?
B-8
Congratulations!Looked like a near new B-8.In many ways I prefer these to the B-9 and later.
Pads-If you are looking at the 3 brown & 3 green you don't need as them as the gold one includes a supply of green pads.You would need the soft pads,either permanent lambs wool type with the snap fastener in center or disposable felt type to use both sides and discard when worn.
To get an idea of what is best for your floors--Read the original owners manual--Consider different types of wax--Consider advice from floor installer/refinisher--Test in small area or closet.
In my personnal experience upgrading to the Eelectrolux floor pro machien whit the 3 brush versous my Kenmore 2 brush system has been the best decision ive made period works like a dreaam.
