I need HELP with cord rewind
zent
saskatchewan
I have an electrolux B-21 floor polisher and the cord rewind spring has come off the one gear and I don't know how to attach it. The spring does not appear to be broke just detached. There is a slot in the other gear but I don't know if that is where the spring goes and if so what holds it in there. I need help.
I do not see a nub, there is a slot but it seems to be at the wrong angle to slip the spring in, do you have a picture of what I'm looking for? Thanks
BE CAREFUL!!!
Those springs are really dangerous. The spring could come free and the razor sharp edges pose a serious laceration hazard! Proceed with caution!
That spring should hook over a nub on the reel or it slips into the slot in the reel. Once you get the spring in the slot or on the nub then take the cord out where it is at the moment and give the drum a couple of winds with the cord and then place the cord back where it was. That way you have some tension on the spring. If the spring is coming off one drum counterclockwise it goes clockwise on the other drum. Hope that helps.
