I kind of don't like retractable hose systems.
amtraksebo1997
Vacmasterthegreats basement
In the past few years, retractable hose systems seemingly have been all the rage, especially in new construction installations, and new players have entered into the sub-business to try and compete with Hide-A-Hose's game. When I first heard about and saw a retractable hose system myself, I was amazed by it. It's so neat and satisfying seeing the hose getting sucked back into its inlet valve. However, in their current state, I'm not as big of a fan of them as I once was. Here are some of my biggest problems with these hose systems.
1. The lack of power nozzle compatibility.
This is probably my biggest turn off from Hide-A-Hoses. This is pretty much a non-issue if it's installed in an all-floored area, but in a carpeted area, you're limited to either using a turbine head or a cordless power nozzle. Turbo nozzles generally don't clean as well as motor-driven ones, and while cordless PNs are a great improvement, I wouldn't want to worry about battery life and charging. Plus, the ladder power nozzles are extremely expensive as of writing.
Now in 2005, there was a retractable hose system made by Cana-Vac that actually did have these connections. It was called the Doc-It/Hoover Hose Magic. While it did give you an electric hose, it too was pretty complex to install (I'm uncertain in these systems could even be retrofitted into an existing home), needed a cap to be placed over the handle when not in use, was more complex in terms of its mechanism, and took up a large chunk of space on the wall, both inside and out. That being said, I wouldn't mind having one of those in my house if it means I could use a PN with it.
2. Potential installation/clogging complications
Hide-A-Hoses need extremely wide curved fittings in order to allow the hose to retract into it. This can make installing such systems more complicated, especially into retrofits. On top of that, the wide fittings mean that you lose the clogging safeguard that a tight 90 gives a normal inlet. So, if you suck up something extraordinarily large, like a pencil or a paperclip, and it makes it through the hose, it'll be free to travel into the rest of the system, where it could and would get stuck once it got past the racetrack.
3. There are better/cheaper alternatives out there.
Why would you add hundreds more to your installation costs when there are other, much better, options. I've already mentioned the Doc It/ Hoover Hose Magic, which is extremely hard to find unfortunately, but there are also stretch hoses available for CVs. When I found out about these, that was kind of the final nail in the coffin for HAHs for me. Now, that's not to say they don't have their flaws (I.e. contracting under pressure), but they pretty much solve most of the problems I have with retractable systems.
4. Why not just use your normal CV hose?
I've often seen people in promotional material for retractable systems struggling to carry their hoses, sort of like the "before" portions at the start of As Seen on TV ads. First off, central vacuum hoses have gotten a lot lighter and more durable over the years. A Plastiflex hose of today is a lot lighter than a NuTone hose from the 1970s. That's not to say they're weightless, but I think you get the idea. Secondly, you gotta be more graceful in how you carry the hose. Don't carry it like if you were a ghost that was entangled in a Proton Stream. I don't have a central vac of my own (hopefully yet), so I wouldn't know the most effective way to carry a hose, but I'm sure there are good ways of doing it. Of course, everybody's physical strength is different, so maybe for people that can't do so, Hide-A-Hoses are good alternatives in those cases. However, for those who can, I'd say just suck it up and learn how to carry your hose correctly.
In short, whenever I do install a central vacuum in my place of residence, I'll be sticking to normal inlet valves.
I've had a Hide a Hose outlet in my house for about 12 years. When I built my house 13 years ago, hide a hose wasn't offered by my builder. They only offered a traditional system so I have regular inlets installed throughout my home and one dedicated HAH outlet in the center of my main level.
The HAH outlet gets used more than any other outlet in my house. It's amazing not having to wind up the vac hose when you're done. I have both versions of the battery-operated Wessel Werk powerheads. I bought the EBK360 head first because it was the exact same as the electric version I have that came with my traditional system but black in color. However, my main level is primarily hardwood floors and wool area rugs so that powerhead is a bit overkill. I recently purchased the smaller EBK250 and it's a pleasure to work with across multiple surfaces. I keep the EBK360 upstairs because my bedrooms are the only area in my house with wall to wall carpeting.
I grew up with central vacs so in my 40 years of vacuum experience, I've never experienced a clog with a central machine. Now I'm not saying everyone needs to have a central vac. If you're someone who doesn't really use their attachments then a regular, portable style machine is fine. However, I really like to do deep cleans periodically and central vac is so nice for those types of cleans. I do use my cordless vac daily but the power, filtration, and ease of use is hard to beat when it comes to central vacs.
OCscott3085
I'm glad to know you love your system. I've got nothing against those who enjoy retractable hose systems. From what it sounds like, one of those seems pretty suitable for your hard floors and area rugs. My mom's house is a similar story, with the first floor being all floored, and the second being all carpeted. Assuming I could pipe one, a HAH would also be suitable for the first floor of my house, but I don't want to for the other reasons I've listed.
Like I said, cordless power nozzles are great innovations, not just for central vacs, but for other things like straight suction canister vacs. However, I'm not really big on them (or cordless vacs in general). I don't want to worry about battery life while I'm cleaning, especially since I can be doing it for hours at a time.
It's also good to hear that you've never had any problems with clogging. That shouldn't be an issue in general as long as your piping is installed properly, and not haphazardly.
In my opinion, if you can afford one, and it's possible to install one your home, then get one. If not, then there are plenty of good portable vacuums out there.
10 years ago when I moved into my house, my friend Evan installed my central vacuum. It is a silent master, the largest model they make. The name is a misnomer because it is anything but silent. It has tremendous power along with multiple motors. I like the HEPA disposable bag. I have had the hide a hose as well as the chameleon, which is my current retractable hose system. The chameleon has a sock. I have three regular electro valves, and a 30 foot Electrolux type pistol grip electric hose to use with it. I could use any power Nozzle I wish. Ultimately, the only thing I use the central vacuum cleaner for is the dryer lint. It's just a long hose with suction at the end. Nothing pretty, nothing buffed aluminum about it. No style or class. One of these days I will have to change the bag, after 10 years I bet it's full. Or not.
Dysonman1
Part of me wants to get a Silentmaster for my central vac install project, however I'm iffy about it, as I'm not sure the circuitry of my mom's house could handle it, and because it might be too loud (it would be going into our laundry room). Anyways, I'm glad you have a central vac of your own and that it's serving you well. However, if I were you, I'd use it more often than just to clean out a dryer vent! You've got yourself a gold-plated sword, and you're just using it to scratch your back :p
If I were to install a retractable hose system (if it wasn't a Hoover Hose Magic), it'd be a Chameleon. I like how you can remove the hose from it's valve and use it in normal inlet valves. However, I didn't like how it didn't have a hose-lock like HAH systems do, however it seems that they're adding that in the latest rendition of it. With all of this being said, I'm still not a fan of them for the reasons I've listed.
Back to your original questions:
1. The newer battery brushes, especially from Wessel Werk are a great addition to the Hide-a-Hose system allowing that deep cleaning. The EBK250 is an amazing brush for hardwoods and light carpet applications. It has LED lights that light-up every spec of dirt on the floor! A bit pricy... but it solves the issue of a quality aggitiation.
2. I too was worried about clogs in the HAH when it first was shown to me in 1999. Since putting one in my own home about 15 years ago I have no problem stating that if it is installed properly this is not a problem. And there are certainly ways to fix any clog in any central vacuum system! Yes, the installation can be a bit tricky especially in some of the more modern designed homes with lots of steel beams.... but it is worth it!
3. The HAH and other retractable systems do cost a bit more. I have had CVACs in my homes for about 45 years. My current home has both regular inlets and HAH but I use the HAH about 20 to 1 over the conventional system! It is truly that much easier to use. But you are paying for the convenience!
4. Why not use a normal CVAC hose? I find that it is actually much easier to install a HAH in an existing home over standard inlets because far fewer inlets are needed. Normal inlets with a 30-hose will cover about 600-650 sq ft whereas a HAH 40 or 50' hose will cover 2000-2400 sq ft! And the extra hose length is so much easier to handle because you only pull out what you need. The 50' hose in my home retracts in 7 seconds!
I appreciate the comments about the Chamelion having the feature where you can pull the hose all the way out and then plug it into a standard inlet. Hide-A-Hose also offers this. But with the HAH you can also pull out only a portion of the hose and don't have a goofy locking mechanism to fiddle with. The new HAH 6000 Pro inlets are by far the best retractable valve available in my opinion.
