I did not set out to rescue a free curbside vacuum today...
Kind of a waste of a higher capacity A Bag.
The A bag does fit, Pete and that's what's in it now. But it is about 5" too long at the bottom, which I folded & tucked under, and can only expand one pleat's worth as the bag compartment is shallower because of the 1.5" deep 'HEPA' pad cavity. Not a HEPA pad at all, it's three layers of scouring pad 'foam' bonded together (white, yellow, green) about 1/2" thick called an 'Allergen Filtration cassette and it is easily vacuumed clean and washable, too. LOL
The headlight area has an opaque filler panel snapped in where a clear lens would go and no lamp socket.
Mike, the XT has a rubber flap valve that snaps shut when the hose is extended, diverting full suction to the hose/wand, the handle of which becomes the nozzle end. Full retraction and bedding of the hose/wand does the reverse - cuts all suction to what is now the vacuum handle, restoring full suction to the brushroll area.
The Hoovers use a sliding gate across the brushroll channel with the hose/tool option slider on the base, that cuts off suction airflow from the brushroll area but nowhere near full suction is usable as the airways up the belt channels either side are open and the hose merely opens into one of these slipstreams.
Dave
Just plain stupid.
I just can't believe someone was so stupid to do this. If I had an expensive vacuum like the Kirby G5, and it wasn't picking up I would at least take it to a Kirby repairman and have him take a look at it before I would put it out on the curb. I wish I could drive and had a small truck, I would be driving around on bulk pickup days here in Bettendorf. You would be surprised what rich people throw away because it doesn't look right, or some other idiotic reason. I would would have a basement full of washers, dryers, dishwashers, and lord knows how many vacuum cleaners I would have. LOL
