How many use this as their normal machine..?
myvacsrock
USA
I do. Even though many vac shops, and people do not recommend these, it is still the vacuum i use the most. It is simple, and cleans great. This is one of the original 1998 ones with no dirt finder (which is fine, because thats just one more thing to break). This thing has seen a ton of use, and i love it.
Anyone also use one of these regularly and also love it or hate it?
Kyle - it is a great vacuum cleaner....
I bought an identical model in green for my parents in 2002. My Dad loved the self-propelled feature and the really long cord (he did the vacuuming in my parents' condo). When they tore out the wall-to-wall carpets and put down laminate flooring, I gave them my Kenmore Progressive ("Elegance" in Canada) green power nozzle canister in exchange for the Hoover SP WT and I used the upright in my little apartment for years. About a year ago, I gave it to a friend who had just bought a big suburban house with lots of broadloom and carpeted stairs.
To me the pros are: Very powerful carpet cleaner, self-propulsion makes it easy to push and pull, lies nice and flat for getting under furniture, bright headlight, long cord, excellent filtration, and an easy to use brush off switch for floors which allows it to do decent job of picking up surface litter and hair from bare floors.
The cons are: too heavy, too noisy, hose is not easy to use and it is too short and you have to fight with it as it wants to contract when the high suction flies through it, upholstery nozzle can damage delicate fabrics since there is no suction valve on the hose and most importantly - the vac tips over when you stretch the hose too far. I also don't like the dust bag set up on all the old WindTunnels - you really have to slide the bag onto the throat in the dark and you can never be sure if it is installed all the way. Much prefer the new T-Series bagged system where the bag sits in a removeable box which has a Miele like bag holder in it.
All in all a great machine, and still one of the only uprights to rate an "excellent" by Consumer Reports in all three cleaning categories of "carpet cleaning", "bare floor cleaning" and "tool air flow". For many years, including 2010, this Hoover Self Propelled WindTunnel Bagged Upright has sat at the very top of the list of more than 30 uprights tested by Consumer Reports.
my opinion....
there ok for the money but i really do not care for them.....the trouble i always have is there not very trouble free. they seem to break and need service regularly, there ok cleaning but i belive you can still get better.
happy cleaning!
jason
I've got the same exact one, except it has the turbo tool. No dirt finder though. It is my downstairs vacuum, and I love it to death. It has been to hell and back, and still runs great.
The Windtunnels are great carpet cleaners. My aunt has had hers for at least six or seven years. She has the bagless model and it is a pain to empty the dirt cup and tap out the filter. When emptying the cup in the trash, the tower filter and the cap seem to roll out of the dirt cup.
I know she doesn't empty the dirt cup after every use and the performance really does decline when it is full. The tool suction was really disappointing until I realized that the handle has to be upright position.
12 amps is just too much for me
Just wanted to add one more thing.. I think twelve amps is way too much for a vacuum to draw. But it has to. In the bagless model I counted at least three filters, so the vacuum motor has to overcome all that resistance.
But they are great carpet cleaners as I said before.
Hey there Matt and Kenny
Interesting comments about the TurboPower 6200 and the bagless WindTunnel.
I don't know if you can compare Kyle's bagged Self Propelled Ultra to these other units though - they have different hose lengths and body weights and filtration systems than the Ultra. Many of the other models in the WindTunnel line do not perform as well the Ultra Self Propelled, and I even think the bagless has less suction through the hose for some reason.
One thing seems to be certain: all the WindTunnels use the "windtunnel" brush chamber that provides for better pick up of dirt from carpets. The separated suction channel that diverts air to the front edge really seems to make a difference when the agitator kicks dirt toward the front of the machine. The only ironic downside is that the WindTunnel configuration results in a really deep "blank" zone of cleaning on the front edge of the nozzle - you can pick up some surface dirt hiding near a baseboard when you push the cleaner toward the baseboard, but you have to lift the nozzle off the carpet a bit to let the suction reach the baseboard. Otherwise you need to clean the baseboard by gliding the vac sideways along the wall, or by using the on board hose with the crevice tool. It would be great if TTI could figure out a way to divert some of the WindTunnel chamber's suction to the front edge of the bumper!
I had the Supreme...
I picked it up real cheap off of Craiglist. Worked very well. The suction was incredible, even after the bag would start to fill. As with most of my vacs, I got rid of it. I myself had no flaws with it. Worked very well.
Clayton
I have a gray/silver self propelled with the dirt finder, made in 2006, I got it this spring at Goodwill for $9.99! I really like mine, but I dont use it very much because the switch is kind of goofed up, but when I do use it, it picks up AMAZINGLY and it is very easy to push. my biggest complaint is that the full bag indicator shows full almost immediately after the bag is changed, so you really dont know if its getting full or not! I usually change it when it shows mostly or all red, and the bag is no more than half of the way to the max line.
uhhh Eurekaprince, my windtunnel has the same hose as Kyle's does (same year even) same weight roughly and the only difference in the filtration system is which one of 2 virtually useless exhaust filters
Jason-
I agree and disagree.. People are dumb, thats why they have issues, i don't believe it is the cleaner itself. I haven't really done any "maintenance" and i have had no issues with the machine.
Matt- LOVE the turbo power, i have had an eye out for one of those myself. No such luck yet =)
piont prooven
but...i stll say it not the best built machine and even more so after hoover was gone and TTI took over...im hust not a big fan of them
Great Windtunnels
I Love my Hoover windtunnels. I have one of the first green windtunnel premiums,I bought it when I worked for Hoover years ago. The only thing I have ever done to it was put a new belt on it every once in awhile. And I bought recently a 100th anniversary model Bagged non self propeled, self propelled, and a Bagless version ( all 100th year anniversary models) so I have enough windtunnels for a while.
I had one exactly like Kyle's, but let it go a couple years ago. I liked it, but my main complaints were with the bags leaking more dust than I liked, and it was just kind of awkward to use.
