How do you unscrew a screw that wont budge
thekirbylover
Warrington, cheshire
So I was trying to take a Hoover Junior U1012 apart for cleaning, however the screw at the rear of the motor wont come out the screwdriver just turns without actually catching onto the screw and when it does it will just slip if put under any pressure I have tried the rubber band trick and it still wont work, does anyone have any suggestions as I really want to get this Junior working again.
Be sure you're using the correct sized screw-driver, I've had a failure of screw in which the screws on a Hoover Kwik-Broom would not budge. Then I bought the correct sized driver and Eureka (Pun intended)! the screws came out with pressure and strength!
WD-40 also works wonders on old, rusty, seized screws!
E-Z Out
E-Z Out screws and drill bits may be your best friends for the most stubborn screws to remove. The drill bits are used to drill a pilot hole in the stripped screw heads or broken screws, and then the twist drivers are used to back out these stripped screws.
If I'm Looking At The Right Screw(s)
If you have clearance around the head of the screw, you can use a Dremel tool and small grinding wheel to grind flats on the sides of the screw. From there, you can use pliers or "Vise Grips" to spin it out.
Might Need Screw Extractor
Well, if you can't grind flats on the sides of the head, you could try drilling the head right off, then use "Vise Grips" to remove the remnant when you do get the motor separated from the body.
I've rarely had any luck with screw extractors, but I've heard the square style works OK. Never tried them myself, so good luck.
http://www.tooled-up.com/product/sealey-screw-extractor-set-7pc-square-type/26254/
Forgot About Drilling It Out
Oops, forgot to mention you may be able to drill it all the way out. If you can drill straight down the center, which is doable with a philips head screw. And, you can find the size of the screw, use the tap drill for that size. If you can get a left handed twist drill that would be the ultimate. For instance, if it's an M6x1 screw, you would use an M5 drill bit.
http://www.amazon.co.uk/Dormer-Spir...A101+Hss+Left+Hand+Spiral+Jobber+Drill+5.00mm
there are much easier and less damaging ways to get seized screws out. that will actually preserve said original screw (as many vac screws were specialty and NLA now)without boogering the threads or screw head up.
i use three methods depending on the severity of rust seizing the screw
1. slighty oversized screwdriver and hammer. pounding a hammer on the end of the screw driver gives a jolting force that can jar a screw loose enough to give you torque with a screwdriver to get said screw loose
2. angled screw driver and hammer. these angled screwdrivers usually have screw heads on either end and are shaped like a hand crank. these drivers are meant for alot of torque just for this kind of problem. this usually gets most screws unstuck for me.
3. if neither of those methods work, i use PB penatrating catalyst (an industrial solvent you can get at home depot) to work on the rust holding the screw in, then use steps one or two after.
4. if none of those methods work, try step 3, but instead of screw drivers, a high torque drill like a makita or dewalt cordless with a screw bit on the wend. preferably and impact drill.
95% of the time tho, methods 1-3 will get a screw unstuck. there is no need to destroy a screw to get it unseized, especially in our hobby where replacement screws for certain vacs cant be substituted with generic screws from ace, home depot or lowe's.
Hey, That's All True...
...but, it sounds like the screw is already fubarred. That's a good point, to head off the problem before it starts. Use the right size screwdriver in the first place, and make sure its tip is in good condition. Heck, make sure you're using a good screwdriver in the first place. If you bought a set of eight screwdrivers for five dollars at the the local grocery store, chances are they're not made of the finest, tempered steel.
Also it's a good idea to see if the screw head is free of debris. Blow it out with compressed air if need be. If the screwdriver doesn't seat in the bottom, you're off to a bad start, and possibly a rounded out head. Lastly, it helps to bear down hard from the start, and make sure it doesn't start to slip in the first place. Once it starts to slip, it only gets worse.
But, that's all moot for thekirbylover. Hindsight is 20/20...
