Hi all, looking for some help. My partner brought me his parents, my outlaws, Hoover steam cleaner, model# F6023-900, because it was not working right. So, took it apart, found the cover/hood was cracked causing a suction problem. Also found the brushes were not going around at all. I took the brush block out and kept going. I found the air-turbine gear box that drives the brush block, removed it and took it apart - very carefully and didn't let the gears come out. The bearing was totally rusted and i think stuck. I loosened it by hand, put it back together and then tested. It works now, but obviously not for long. There was also a huge glob of grease on one of the bigger gears that was not eveny distributed at all.
So, I ordered the new hood. The turbine assembly is NLA but I did find just the bearing. Has anyone replaced one of these? How much grease should be in that gear box and what gears should it be on? It almost looks right now like the machine was on its side all the grease melted, and then solidified in the wrong place.
Everything else on the machine looks good. The turbine for the sprayer works just fine, and now that I cleaned out the brush block, it should be fine as well.
If anyone has any advice on replacing the bearing and greasing the grears, please let me know.
Thanks!
Andy
PS I will get some pics, but right now I'm just lazing around because I have that horrible cold thats going around vacuumland.
Thanks!
Andy
