alexhoovers94
I was lead to believe that the Hoover Turbopower 3 autosense models did not sense as well as the turbopower 2 autosense and 1000, is that true? And if so, why? Was it just because the hose was longer and it took longer for the dirt to get to the sensor?
I also read somewhere that the hose on these models was far two narrow for a clean air machine and that is might of put strain on the motor, well when I took the hose off and put it back on when the machine was running it didn't sound like the motor was being restricted so is this true?
I heard that these machines clog a lot, now I haven't had that problems yet but apparently that is because the dirt channels in the cleaner head were larger that the diameter of the hose so things got stuck? And finally where is the air fresheners supposed to fit? Does it go in the post motor filter cage?
Any suggestions will be gratefully appreciated.
Alex.
Alex.
