Hoover PurePower, what happened???
I do run a business Benny.
And Nar makes a good point. Vax produce better quality than Hoover/Candy you can pick up a Vax Air for around £100. I tell you if Hoover keep producing junk like this the British public will switch to another brand.
The British public have already jumped ship ; everyone is now buying Numatic Henry vacs or Hetty; they're mostly all realising that it is not just schools that they are fit for.
Yet when you look at the actual design and tech, the Numatic Henry isn't technologically bristling - but they are durable, long lasting, fairly easy to run on cheap dust bags and all the while HUGELY economical due to the massive dust bag capacity, long hose and long cord.
Albeit the long hose and long cord, when was the last time I could find cheap dust bags for a long lasting durable vacuum cleaner? Oh yeah, the Hoover Junior and Senior.
Yes Numatic have a simple design that is well built and very reliable and best of all built here in the UK :-)
Wish they would introduce a telescopic wand though, I hate friction fit.
And actually there's the irony. Instead of trying to copy every brand, just how difficult would it be for Hoover Europe to re-release the Junior or Senior? Or something similar to that? When you think that in the U.S, bagged uprights still sell (cue Sanitaire), UK consumers could well be honoured with a decent built metal & plastic combo based bagged upright. Even the Turbomaster could be brought back.
Oh yes that would be good.
I may well get a Sentria shortly.
I've been doing some research into high end vacs both cylinder and upright. Rainbow TriStar, Filter Queen, Royal etc and I've come to the conclusion Kirby is the best option.
Rainbow makes an excellent vacuum, but I do not like messing with the water and water tray maintenance. Therefore, Kirby is the only way to go.
There are things I like about Rainbow but I wouldn't buy a new one I don't think they are worth the price. Sadly you rarely see used ones on EBay in Europe.
Nice vacs though.:-)
I have just bought one of the new Purepowers with the 750w motors, infact the same one in the picture at the top of this thread...Yes it is cheap-ish, but it is not terrible for a Chinese made vacuum.
This white and red model PU71 only retails in Argos for £89, the Purepowers originally retailed in Argos for way more than that the base model was £128.50 in 1997 (also pictured at the top of this thread). I have the original top of the line 1997 Autosense Purepower and that was £199.99 in Argos!!
The Original Purepowers, depending on the model, had features like Autosense, variable power, bag check light, permabag and air fresheners...All that has been axed now on the newest models and the only features that remain from the very original series are the self sealing dustbags and HEPA S Class filter.
I do like the older Purepowers, the ones that were made in the UK (97-2003ish) they also had a better brushroll, it was called an activator, similar to what the Turbopower 1s, 2s and 3s had...It was a spiral bristle brushroll with beater pads on it...However, some very early models (including mine) didn't have the Activator brushroll, it was similar but without the beater pads, it also had rotating edge cleaning brushes, where as the activator version didn't, that just had static edge cleaning brushes.
I think the newest Purepowers preform just as well as the old ones but they are just a bit louder and they have that cheap vacuum brushroll noise, you know, the "EEEEEE" where as the old ones from the late 90s didn't.
I think it is very good value for money, the Purepower, I mean for £89 you are getting an upright vacuum with a self sealing dustbag, HEPA S Class filter, full 13 stair stretch hose and 3 separate cleaning tools.
The only thing that lets it down is the handle release, which had been a problem for years.
Contrary to popular believe, the Purepowers have not always had a bad handle release, it actually used to be very strong on the 97-2000 models as those ones had a metal string inside the pedal/button...With the spring in there, which formed the tension on the release button, made it very easy to press down and release, however, on later models and indeed the newest models, they just made a spring action out of the moulded plastic pedal and did away with the metal spring, making it very difficult to press down to release and also weakening it, as they changed it to all plastic. It is hard to explain but I hope you understand what I mean.
So, I thought I would show you my top end 1997 Hoover Purepower next to my 2015 Hoover Purepower.
Furthermore, Alex, as I wrote in the earlier messages, not only did a base-model Purepower retail for £130 in 1997, that equated to £213 in todays money.
So to get that same cleaner for £89, one would have to expect a huge drop in something somewhere.
Even Down to the motors...see the difference in motor size. The one in the new Purepower power is just a cheap generic vacuum motor where as the motor in my 97 Purepower has an Italian made Ametek motor.
15 motor...
