Hoover Guardsmans
vacuumboy23
Active member
California
Gosh you guys wont believe the story im about to tell.
It all started on the first week at school! The maids had 2 hoover guardsmans to vacuum the school. They both used the guardsmans for about 4 days. But on Friday I noticed one of the maids took out an old hoover elite! The elite worked for almost all of the school year but in March the brushroll cover came off and they threw it away even though it was an easy fix! They went back to the guardsmans for a little but then one of the Guardsmans stopped working and a school administrator took it to be repaired. Then the same School Administrator bought them a shop vac to temporarily replace the broken guardsman.. They used it for about a month and then a new vacuum arrived! The same school administrator bought them a hoover supremacy which was included in Hoover Special Supremacy Series. I was shocked to see that vacuum be picked up from a vac shop because that is a rare vacuum if im correct! So... the Supremacy was used along with the Guardsman. Then one day the broken guardsman was fixed but the Other one broke!! A few weeks later the other broken guardsman came back but the followng happened; the vacuum was plugged in, turned on, the motor turned on, then died -_-! So one of the maids were still using the supremacy and the other one was using the working Guardsman. Then the maids complained that the Guardsman broke a belt every week or so which was horrible! This shows the quality of hoover today! So the school kept on buying belts for guardsman every week or so! Then just last Friday the other Guardsman broke a belt and there were no more belts!!! So the maid took out the old broken Guardsman and it turned on!! Guess there was a secret trip to the vac shop! Yesterday the maids replaced the belt on the broken guardsman and they were using both guardsmans just like the first week of school since the Supremacy broke a belt as well! (One of the maids likes to use the Supremacy instead of the Guardman. So just today guess what happened? The other guardsman broke a belt again!!!!!! So one of the maids are now using the shop vac!! I'm thinking of asking the school administrator for the Supremacy due to that it is no longer needed!!!
The end!
Also can any of you guys tell me what an appropriate heavy duty commercial vacuum would be for a school?!! (I'm trying to get new vacuums to replace the hoovers!)
So what do you guys think of what happened?
