Hoover Elite Wheel Removal
Elite wheel?
You are not likely to have a broken rear wheel.The problem with Elite rear wheels was changing from metal axle(that worked fine)to plastic axle(which could cut into the base housing with heavy use).As I recall to remove wheel place flat screwdriver at outer side of wheel and pull away from wheel.The housing will flex enough to allow axle to drop out.
