Hoover 63 Blue & Gray serial A11...
hoover 3 kirby d50
side by side
Can't decide
love the kirby sound
sounds strong & is stunning
think the agressive roller on the hoover really sets the nap
still they don';t suck like a freshwindtunnel...
height adjustment works
just have to use foot & some effort
that's nice
Spring Loaded flap
Your model is similar to the UK 638 which shares the same basic design as the previous UK 612.
The tools converter slides into the tools port on the side of the cleaner.
With the cleaner in the upright position, press down fully upon the rear chassis of the machine, near the handle. The rear suspension wheels will move closer to the body of the cleaner. Keep the cleaner in this position by maintaining your force. At the same time, fully slide the tools converter into the port (this allows the converter to penetrate the spring-loaded flap, close to the fan). Release your force upon the cleaner body (the spring-loaded wheel suspension will lock the converter in place).
To release the tools converter, apply force to the rear of the cleaner, withdraw converter. The spring-loaded flap will reseal the suction port automatically.
thanks
so there is something inside...anyway I don't have tools for it & don't feel suction at the end so the flap must be closed.
Only 2 heights for the head
was trying to figure if there was a way to adjust roller height etc for wear?
tried loosening screws on brush strips but they just hold it
& loosening them just makes the loose.
Interesting cleaner esp for its day
like the strong construction
Saw a similar mod 62 & someone got it for $10 plus shipping
same color but looked like the base was painted taupe over orig gray. It was also a side load tool so fairly old
orig bag but not in great shape w a orange cord...
might have liked parts but I think I like the kirby better as I can adjust the head for suction.
Old vac does a decent job & in its day was quite the machine
The model 62 is beige with the blue trim. The model 63 is grey/blue with the blue trim. The 62 had a handle grip and used the "Handisac" type W bags no longer available versus the 63 that used the C bags. The 63 also used a shorter handle and no grip but offered a full wrap around bumper. The 62 in the Ebay auction was original save for the cord which is easily changed. The blue original bag is in great shape and VERY hard to find. These machines cleaned very well on all carpet surfaces and used the revolving beater bar to make the grit come out of the bottom pile of the rug unlike the Kirby that only had brushes to do the vibrating. The toe shifter locks the rear wheels up when vacuuming unusaully thick rugs. Mostly the 62/63 was self adjusting to most carpets.
--Tom
thanks
Arrgh...if there was no shipping I would have got it that is who knows how much the other bidder would have went
Least I got mine & it works pretty good but it sort of lays the naps sideways & the kirby leaves it more upright.
Thought is was nice but I see not being able to get bags as a problem & the bottom bag part inside did look wider than a fng bag. I don't mind the f& g bags as thats what my royal takes. Someone got a nice vac as it was really clean
