61
Not a bad find, needs a little TLC, has the original bag and thats not a bad thing! The brushroll may be rare to find, but I may have one lying around that could fit it. There is a thread in the archives that explains the method of greasing the lower bearing on a convertible. It may not be to different from that. I recently greased the bearing on my model 26. You have to remove the motor, remove the fan, the washers beneath it, and a small ring/sleeve that fits between the bearing and the armature shaft. The space thats left after that is removed is where you fill the grease in. I normally try to gently scrape away the old hardened grease and use a flat bladed screwdriver to gently tuck the grease in. Hope this helps!
