Hoover 450 motor problem
zenith12
Active member
Canfield Ohio
What would cause a motor to run nominal then in a few seconds it slows down and then back up to normal rpm I’m afraid that this might damage the motor so why would it do that and how do I fix it.
Assuming.....
something the motor is turning isn't the problem....brushes, commutator, commutator segments, armature windings etc.
Good YouTube vids on testing armatures.
I have a 1205 motor doing exactly this, but haven't gotten into it yet....pretty sure it has fresh brushes.
Kevin
Check brushes, check all electrical connections. Quite possible one connection is going high resistance for a moment and gets jarred back into place.
