heritage II shake out bag with emptor needed
kirbyuser
milford,ohio
i haven't been real clear on exactly what i needed. i need a gray shake out bag with emptor for a heritage II. i was also told i need to change the axle so it will fit. i have two heritage I. both have shake out bags & one has the rare 13" rug nozzle. adambomb might have what i need. let me know. i want to keep the original gray style bag for it.
you can get the rear axle from any heritage I or tradition. it will work just fine. the bag is extremely rare. i traded an amana radarange for one new in package. finding the black crackle paint sani emtor is even harder if you dont get both together. best bet is vacuum shop back rooms/ basements for this. any place else and the time to get it will be significantly longer.
heritage II axle
i have found out that you do not need to change the axle. you can move it over & only put one screw in it & it works well. yes the left side wheel sticks out some but still works. it just looks a little funny.
vacuser
I would still recommend purchasing part no. 102080, of which plenty can be found on parts Traditions or Heritage Is. I remember about your two Heritage Is, both of them Heritage 84s (and one which has the 13" head), from an earlier post you made.
vacuser
If you cannot find the black hammertoned Emtor casting, you can still make a Heritage II shake-out assembly using the following parts:
179978 or 180069 polished metal casting
189684 bag cloth (short zipper)
185984 black tray bottom
191684 black bag guard
