HELP!
rainbowjoel
Dexter NM
I have a Hoover Convertible not original motor. I tried to connect the headlight wiring and blew twice the bulb. I guessing doing wiring wrong. Can anyone can help me. Thanks Joel
headlight
You dont need a resistor, I will look on one of my headlight convertibles tomorrow afternoon and tell you exactly how its wired. I can tell you right now that one of the wires should not be on the carbon brush connection. Someone will probably help you sooner than I canm if not I will post my findings in the afternoon, after work. Good luck, dont give up yet!
more than a day...
Yes, it has been, thank you for pointing that out (note the sarcasm). I will get a pick out, trust me, lifes a bee-atch right now.
soldering
Dont wire it directly to the field coil, in the picture there should be ports like the one the wiring goes into. Since all hoover motors would have been "universal" to accomodate a headlight assembly the field coil should have an opening where that wire would have gone.
