brownvacuum1987
Hello Vacuumland! This is [Unfortunately] my first post on the Website. I seem to have run into a problem with an Electrolux Motor. A reminder that the Immortal Electrolux Canisters ARE indeed Mortal. I have recently got an original 1987 Electrolux Marquise [1521] cleaned inside-out and working again after it had sat in a basement for Six Years. It supposedly “died” in 2004 when sparks started coming out of the exhaust. I am not exactly sure what made it work again after simply cleaning it out, but I have recently noticed that it is on the verge of sparking again. I’ve opened the blower-door while it is ON and have seen blue flashes under the covering on the motor, and have noticed that the Machine slightly sounds different than it did days before.
I’ve done some research on how to repair these Motors and have ultimately found that it could the brushes or the armature needs to be replaced. However, I have no idea how to take the Motor apart or where to even find a new Armature and brushes on the Web. Could it be possible for you guys to explain how to take the Motor apart? (Pictures would be helpful! Though not required.) In addition, perhaps send me link to the right Armature and Brushes? That is if someone online sells them.
I have taken the motor out and it appears someone has already done this to the Motor in the past. Someone used a Sharpie to write on the Motor “Replaced Arm Kit – 1/28/92”
I have taken pictures of the Motor and have attached them in this Post.
Thank You
-BrownVacuum1987
P.S. I have NOT joined Vacuumland because of this issue, seeing that there are many other Electrolux Fans on here it seemed like the right choice. I intend in the future to write posts of my own Vacuum collection!
Thank You
-BrownVacuum1987
Safety Reasons?
