Help! What is happening to my Rainbow
speaking of Rainvac
Is that like an online "Authorized" dealer or something?
I'm thinking not. It's a super nice website that only deals in Rainbow and sells only genuine parts.
It's true - if you can fix and repair a rainbow, you're almost sure to make a profit. Too bad I don't know how to fix crap.
Which part?
The only part I'm seeing from RainVac for the controller is the whole controller for almost $300. I'm not investing that kind of money into a machine that needs a couple other parts, only to sell it for barely what I have into it for parts costs alone.
Well if the vac is junk as it stands, you can't make it worse. Take this opportunity to try and learn how to repair electronics. :D
It wouldn't be too bad, if I knew what was the main cause of these problems, and where to find the replacement parts.
I've dipped my toes into fixing all types of things over the years, and this type of electronics repair hasn't been one of the things I've mastered.
I may have to wait until everyone is back up and running, and take it to an electronics repair person with proper tools and skills. It would still have to be a lot cheaper than spending $300 for a new controller. The downside is, it's still a failed design, and it will die again at some point, unless I can figure out a way to modify the Rainbow itself for better/cleaner cooling of the controller.
I've used RainVac before, they were very nice making sure I was getting the correct part for the right unit. I think the closest Rainbow distributor is no longer in Mt. Juliet anymore and there might be one still in Knoxville.
Controller
I see the controller. It's basically everything electronic for the vacuum runs through it. I thought it was small board.
I'll tell you what to do. If you know a vacuum dealer or someone who fixes them. You find a used one. If you can't it's a parts machine.
I didn't realize it was a $300 part.
You can find one I'm not sure of the cost. If you want money out of it this is it.
In all reality, it'll be nearly impossible to find a used controller. It's the most expensive component in the entire machine, by a large margin, and it's really the only bad part that would keep someone from fixing up any other issues with one. That's where I am, with 2 of them...
Even if I found an E2 Blue dirt cheap (they're out there), it would be wiser to just fix the issues with that machine, versus swapping the controller into a Gold that's not worth as much, nor designed as well. The only possible way would be a Blue that is literally destroyed on the outside.
Finding another dirt cheap Gold will raise more concerns. Does it have an updated controller? Doubtful, meaning its days are probably numbered, no matter how well it runs when it's acquired. Anyone who knowingly paid the money for a new $300 controller won't be selling the machine for much less than that.
In the end, I have some good parts. I may keep them for fixing up future acquired machines, or sell some of the parts. I got my money's worth with some accessories I needed for my Blue, including the 4 qt basin (new), inlet cover (new), inflator/deflator tool with coil wand (new). There are 2 good separators, latches, seals and motor units, hoses, wands, power nozzles, dollies and a few other attachments. There are some other accessories for an Aquamate and others. For $50 for everything, I knew I'd be ahead, even if the machines were toast.
