Help needed identifying a hose
gmerkt
Edmonds WA
This may or may not be less than 20 years old; the construction technique is of any older style. What does it go to? Royal canister? No, it's not an Amway Cleartrak hose.
Windsor
It looks like the grab and suck hose used on the Windsor uprights for commercial use.
In looking into this further, I'm starting to go back to the idea that it's a Royal tank vacuum repair part. I got thrown off the path because the tube didn't have any fittings on it. It's a new old stock part and has never had dirt through it. In looking at Royal parts schematics, they show the fittings as being supplied separately from the hose tube. That's why I believe it's Royal. Thanks for your replies.
May be for a Kirby
I had one very like this in red some years ago for a kirby used for cleaning a long run of stairs, a Kirby service shop in nottingham got it for me
Wet suck up hose for Vacu-Queen Central vac
Thanks to the help of an outside resource we got your answer. Unfortunately can't find any photos of the attachment.
This hose was designed to fit the Aqua-Queen attachment. A water pick up attachment. The Aqua-Queen attachment was used on the Vacu-Queen Central vac which was made by Filter Queen.
