Hello, and asking for help with an Electolux polisher, 1960s
BalkaRoo
Bunbury Western Australia
G'Day blokes, from Western Australia. It's a very interesting site you have here!
I am wondering if I can get some help from some of you with an old, "very old", early to mid 1960s three brush, made in Australia, Electrolux domestic scrubber polisher. This was my mum's unit purchased I would recon about 1964 or there abouts and is a 32volt DC machine. It has lost drive to two of the brushes and I would like to find out what is inside the drive case, that is, is it gear drive belt drive, friction or whatever, and how do I get access to it to repair it. Are there any schematics or online maintenance manuals for these. I have had a look and can't find any numbers plate on it for model identification.
Thanks,
Graham
I just went out and cleaned it, and found the ID plate under the handle tilt area, so on the plate reads-
Model B9
Ser 0 (Ithink, but could be C or G, its a bit damaged)
Number ME 0078742
Volts 32
Watt 250
Mum would have purchased it about 1964, but I don't know if it was new or second hand, it may be older.
Unfortunately condition not good, but some of us would like to put together a small display of 32 volt household appliances for display at vintage days as a ladies interest thing, and if I can get it running and make it presentable it could be part of the display.
Thanks Guys,
Graham
I got it apart, and the problem was just the belt. It was rotten, but intact when I got it apart but incorrectly installed with the belt running around the drive pulleys, but "not" being taken up around the motor drive shaft, so "no drive". I suspect my "mum" tried to replace it and didn't realise where it went after it originaly broke, and I doubt "Dad" would have lowered himself to put it in. I always did wonder why she stopped using it!
Are these belts or a usable "elastic" belt available anywhere, or will I have to try and make something ? I have looked at a couple of Electrolux websites and they don't look like they are available from the manufacturer anymore.
Hi and welcome, Graham.
AB Electrolux's B9 Floor Polisher was designed by Sixten Sason (1912-1967). The first mention of it in an online database was in 1955 (see attached snippet view), and it was made in various series for different worldwide markets denoted by a single letter as you mentioned. So technically, it would be a B9a, B9b, etc. These may have debuted in different years; it's hard to say without company literature. It was replaced in the UK by the model B19 in the mid-1960s, so your mum may have purchased it new in 1964.
I located a UK belt listing for the B9 and a variety of other models at https://www.paxanpax.com/47-EL-05 (a screenshot of the page is attached for future reference if the part becomes NLA at some point).
Congratulations on owning your mum's polisher, a popular vintage Electrolux model. Keep us posted on your effort of getting it back to working order by replacing the belt and going through the motor.
Here's a link to Electrolux Group's polisher history: https://www.electroluxgroup.com/en/the-rise-and-fall-of-the-housewives-favorite-26778/
  • Electrolux Polisher Belt for B4, BC4, B9, B19, B21, B22, B23, B30, B40, B132, B37 - paxanpax.com.png
    247.8 KB
  • Electrolux Group website image of Sixten Sason's drawing of B9 polisher.png
    532.3 KB
    36.1 KB
It's got just a flat elasticised belt that runs around the pulleys on the brush shafts and then up around the drive spindle on the motor and back to pully line again. It looks like it should have a "stretchy" belt so it can get tension on the "fixed" pulleys as there are no adjusters that I can see, and the old rotten belt was still intact when removed, but broke when I tried to stretch it over the motor shaft. I have in the past made a belt for a valve refacing machine that the manufacture couldn't supply out of layers of "bookbinding tape"! I don't think I want to spend nearly fifty quid UK plus postage to get it out here, so as it would be minimal use anyway that will probably be the way I go. The motor still turns freely and "looks" in good order, but I haven't tried it on the transformer yet, but probably will over the weekend. Is there anything in particular I should do to check out the motor before I power it up? I wouldn't like to "fry" it after 50 years of "slumbers"!
We moved out of the old house in 1973 and the polisher hadn't been used for some time then, but the new house had 240 volt AC mains power so a 32 volt appliance was no use and it just got left in the old house, unloved until I grabbed it last weekend.
32 volts is so unusual. Is that an AC or DC voltage? Would homes have 32 volt outlets?
32V was common in homes that were not on a power grid, and had their own little baby power plant. Usually a one cylinder engine and a battery bank. Farm houses, mostly. Light bulbs and appliances were available in 32VDC.
Wow. Interesting. So the home ran on DC or was there an inverter?
The 32 volt DC power plant was a 4 HP Diesel with a direct coupled 1500 watt generator charging a battery bank of single cell batteries, we did have a "rotary inverter", basically a single unit with a DC motor on one end and a 240V alternator on the other end, which from memory was 240volt 750 watt and used to power the TV set when TVs came in about 1960. 32 Volt was almost "universal" in the country farming area I grew up in, and only newer built houses or very well off people had 240 volt AC alternators, my grandparents did have a Lister alternator but they built a new house in the 50s. The inverter only powered the TV and sometimes a portable appliance like a radio or record player, the other household appliances including vacuum cleaner, lights, radio, Iron, blender, fan, mixer and even a shaver all ran on the 32 volt power !
And yes "Cheesewanton" the house had several "Hotpoint" plugs in the usual sort of places. The Hotpoint plugs were a two post plug with round pins about 3/16 inch thick, that you could push in either way but being DC it didn't matter they would work no matter which way they were pushed in.
Well, I checked and cleaned everything on the polisher today and jerry rigged a cable onto the terminals to find out if the motor was still operational, I do have a plug, but the original cable will have to be replaced, so after verifying it all "looked" OK I switched on the transformer, "and nothing happened"!! Then I remembered, no on-off switch except on the handle, so tripped the small handle locking pedal, lowered the handle and "away it went", just like it had been switched off yesterday. I don't think it had run since about 1970, but the switch, motor and wiring all seem to be operational. YIPEE!!!
The motor would obviously be dry from sitting so long, do you guys think I should oil the armature bearings, which look like they may be very awkward to get at, or should I just "leave sleeping dogs lie" and not disturb anything?
Thanks guys,
Graham.
This is it hooked up to the transformer!
There would be a gasoline engine to keep the batteries charged and then the whole house ran off the battery bank. In the USA after 1935 when Roosevelt founded the REA to get electricity out to farms, these home power plants became obsolete. Not sure about Australia's situation but I am sure many people used them way into the 50s in the outback due to how remote the area is
https://www.farmcollector.com/community/farm-shows/delco-light-plant-zmlz13janzbea/
    49.1 KB
    124.4 KB
    1.5 MB
There would be a gasoline engine to keep the batteries charged and then the whole house ran off the battery bank. these home power plants became obsolete. Not sure about Australia's situation but I am sure many people used them way into the 50s in the outback due to how remote the area is
A lot of Australian farms never even got 32 volt power until the late 1940s, although available from the 20s on, it was too expensive for the average person to afford so remained the preserve of the "well off". Mains power was rolled out in the late 60s up until the 1980s. Local towns had large generating sets that ran the more populated areas but outside the town limits you had to fend for yourselves. There were 32 volt installations in some of the "very" remote areas probably up until about the turn of the century, I know of two local family's that were still using 32 volt until the late 1990s. In our case the power came through in 1975 but the new house was set up to use the mains power we knew was coming so from March 1973 until July 1975 the new house used a portable 240 v generator.
The thought of a gasoline powered generator scares me but I guess diesel engines and diesel fuel were not too common in the US until after WWII.
It makes sense but having never lived anyplace that remote it never occurred to me that people had such generator and battery systems in their homes.
They were actually situated at least 20 or 30 feet away from the house so they wouldn't set the house alight in case of a fire, and also because of the noise. We actually had a fire with the "original" lighting plant that damaged but didn't "destroy" the engine room. That engine was a 2 1/2 HP gas engine, and after that dad replaced it with a second hand Diesel that was redundant because the mains power had come through in that area.
I have seen people remove bearings, pop the shields off if they were shield bearings, clean and regrease them, replace the shield and reinstall the bearing. Just me but as inexpensive as bearings that size are if I have a used bearing in my hand it's going into the recycle bin and a new bearing will replace it. If it's a situation where the bearing won't come out but you can finagle the shield off and get some fresh grease in there then that is a different story. But new bearings are inexpensive enough I don't see a good reason to regrease old ones once you have them in your hot little hand. Just put a new one in.
If the bearing has a viton seal then you replace it in every case.
I asked "AI" and he/she recond that all the B9 models including the 32 volt type were ball races. Don't know if I believe it or not, sometimes the AI just repeats miss information, but looking at the motor it looks like it most likely "is" ball races so I think I will leave it alone. Looking at it I think it would be a brute to get at the bearings without damaging something else!
Thanks guys,
Graham.
Australia had 32 volt appliances, mostly farm property and the rest was ships from memory, farmers were first to use electricity and the emerging appliances and you certainly had money to purchase these appliances ( definitely exclusive to the wealthy before 1920s) growing up I came across a lot of these 32 volt appliances, ceiling fans from about 1900 washing machines which were basically a drum with a motor bolted next to it were 32 volts also, and crude vacuum cleaners again looking like a drum instead of of the shapes we love today,interesting fact, Marelli Italy built their dc motor to withstand 32 volts up to 240 volts varying and only approved delivery of such motors following a night of continuous operation without issues on all voltages, how superior is that quality compared to elcon Australian who built motors barely surviving the 32 volts designed to operate on, in hot climates
Yes, you are right about such things as "ceiling fans" being expensive in 32 V, I have only ever seen one set, and that was in a "mansion" owned by a "Very" well off family. They also had 2 top of the wazza generator sets. 1920s Willys Knight-light sleeve valve engine and generators
sets.. Super quiet and Horrendously expensive. The washing machines weren't so bad, we had one on 32V but others in the district had "Pope" washing machines fitted with Villiers "kick start" engines, similar setup to the US "Maytags"!
Were there companies in Australia that came around with tank trucks and filled a gasoline storage tank? I know there are companies in the US that do that for farms with fuel storage for their farm equipment and for construction sites to refuel the graders and such.
Yes, fuel company's such as Shell, BP, Mobil, Ampol, etc have had trucks that delivered both bulk, pumped into overhead tanks and also dropped off 44 imperial gallon drums (50 gal US) onto farms for "decades". Back when I was young, almost all the fuel was delivered in drums, and the fuel company's had "drum depos", at some of the small local stores, post offices etc, where if you ran low, you could go get some petrol, kero, Diesel and crude oil to tide you over until the fuel truck/tanker came through, but during the 60s most of the farms got overhead tanks. Our farm that my brother still runs has 5 such tanks, the smallest being 250 gals (imp) and the largest 2500 gal (imp).
In the early days when my grandfather was running the farm, fuel came in wooden crates with 2 square 4 gallon tins in them with fuel and oil of all types. I still have a couple of "Plume" motor spirit and quite a few Shell, COR, and Caltex kero and oil boxes, they were branded on the wood and are quite sort after by collectors. (but they can't have mine!)
I see. I paid for grad school driving a tanker delivering fuel to those overhead tanks, construction equipment at construction sites, power equipment in boat yards or at hill top water tanks that were being refurbished. It was physically hard work!
