Hall GrindoVac
Yes, Les got it. Not sure if it would have had a proprietary bench grinder or you could fit anything and it just used a hose, but you switch the vacuum on, switch the grinder on, and all that dust and grit will go into the vac and into the bag instead of in the air. If you ever find a Hoover vacuum bag cleaner, this would be the perfect sister piece to that for sure.
