aeoliandave
Well, that turquoise Flobee Pet Groomer hose was begging to donate itself to the Roll-Easy cause. Bound & determined to do the right thing I removed the GE O ring bumpers from the woven hose ends and patiently worked a long thin flexible bit of hardened steel under & around the hose, going in a bit deeper each rotation. This eased and sliced through the rubber cement. I detected that the GE hose nozzles have a shallow raised screw pattern. All that easing gently separated the hose rubber from the metal and with firm grip & twist, the ends came free with no damage to the woven or rubber areas.
So, the woven hose is saved for some other transplant project, having gracefully donated its GE ends.
