I figured this was the best area to post this question since it relates somewhat to appliances, or general electrical wiring and somewhat to vacuums. First a bit of background, I had a 240 volt outlet installed to power my 240 volt central vacuum units. It turns out that in my kitchen I had a 240 volt hook up for an electric stove that I am not using since my stove is natural gas. In the dining room is an outlet that branches off from this, apparently it was originally a 240 volt outlet, probably used for a window air conditioner but was converted to 120 volt when the apartment building got central air. Since the wiring was already there, it was very easy for the electrician to convert it back in to a 240 volt outlet. In the kitchen is a small box that controls this circuit and it has two 20 amp fuses in it. Now for my question, I have heard that fuses are available that actually have a circuit breaker on them so that if they do blow, you simply reset them like a circuit breaker rather than having to replace them. Of course, if this continues to happen it probably means you have an electrical issue, everything is working fine, I would just rather have circuit breakers instead of fuses installed here. The fuses screw in like a light bulb so I'm assuming they are Edison screw, is that a common standard for fuses? I've searched on line for circuit breaker fuses but have not come up with much but I have read that these are also called minibreakers. Does what I am talking about even exist and if so, is there an official name for them? Come to think of it, would there even be a demand for something like that anymore since everything now uses circuit breakers which would make fuses obsolete? Hopefully what I am asking makes sense, if not, let me know and I will try to explain better.
Mike
Mike
