Floor-Pro Perfection
How does the Genuine shampoo compare to the Stain-X brand I order from Steel City Vacuum? I've yet to have an issue other than it not foaming up like the Genuine shampoo used to.
I have three of these Electrolux shampooers, all 3 belonged to my (Now Late) Grandmother, though one had been traded off and I Re-Acquired it.
(Also ignore the rug it was in my Aunts basement)
Lux Floor Pro
Tom,
I have one just like that. Works great with Lux or Kirby Lavender suds. I find the Riccar Impeccable a bit better at crystal removal time than the Lux due to a little better agitation but the Platinum with Omniflo and green bristles works pretty good. Remember the commercial with Brian Gotta and the 4 year old? Clean rugs don't come any quicker or easier. Sold several to a Hospital and Jewish temple in Boston. Still in use a decade later. Glad they dumped the cord winder for a longer cord you can actually use. Looks good!
Brian
Looks great, but all that leftover chemical residue..
Can the Lux rinse all those shampoo chemicals out, after that rug has been embedded with them? If not, even after vacuuming, the rug is permanently saturated with chemicals I wouldn't want to touch. A proper rinse is likely needed. In my mind, just like with laundry, rinsing after washing is crucial. I'd suggest going over it with an extractor filled with cold water, just to be safe. If you do so, I bet you'll get lots of extra dirty water as well! Happy shampooing!
Actually, if you mix the genuine Turbo Shampoo with water, and allow a drop or two to dry on the counter, it turns into powder. No greasy residue. The Air-Way Signature Series (on "low" speed) will beat the carpet very well and remove every trace of the powder as soon as the rug dries. I love watching the Air-Way's "RugMaster" power nozzle beat the rug after shampooing - the powder jumps six inches up from the carpet as the RugMaster goes over it.
Mike:
The RugMaster on the Air-Way Signature Series was made for Air-Way by Cen-Tec with a few differences from other nozzles they made. The Red fully tufted brush strips are very unique to that nozzle. Stiffer than the Kenmore brushes, the RugMaster brushes add a beating effect - in addition to the beater bar itself.
When an Air-Way Signature Series is run on "Lo" speed, both the vacuum's suction motor AS WELL AS the motor in the RugMaster slows down. Perfect for cleaning area rugs without dragging them, while beating the stuffing out of them to remove the grit. So the Air-Way will Beat...as it sweeps...as it cleans!
You have another Rugmaster on the way!!!!
Tom, I'm packing up the Centurion this afternoon. I'll notify you when it ships and I'm not cutting corners on packaging. It'll be double-boxed and bubble-packed very well. Do you prefer USPS, UPS, or FEDEX?
gottahaveahoover
Thanks i vacuum twice whit my compact c9 then wash and wax and polish whit my floor pro took 2 days but was sooo worth it thank you.
