The Eureka ESP Self-Propelled vacuum at my local food bank was in rough shape, so today I did some repair work to it.
First, I went to change the bag. This vacuum uses F&G bags, which are a struggle to remove and install. The old bag was not full and was FILTHY, so I had to change it. It was a struggle to remove the old bag. When installing the new bag, I had a lot of trouble getting the collar to stay wrapped around the paper tube of the bag. Eventually, I got the collar seated correctly after about 5 minutes of struggling.
Next, I changed the belt. This vacuum uses RD (round rubber) belts, which are just as difficult to install as the bags. When I went to use this machine for the first time in a while, I noticed that the brush roll wasn't spinning. I took off the bottom plate, and found out that the vacuum was burning through the belt! When installing the new belt, I had to really stretch it around the motor shaft. It took all of my strength to get it seated correctly, and I had to be really careful not to pinch my thumbs.
Once these parts were installed, the vacuum worked! It sounds like a lawn mower.
Do you think it's this much trouble to perform maintenance on a Eureka F&G upright? I haven't had much experience with vintage vacuums.
