vacuumboy12
Well, I finally finished up my central vacuum install.
Bought an MD Flowmaster 650T from a local dealer in Oregon City, with super valves and a high voltage hose/ Sebo ET-1 powerhead. Very happy with the end result. I’ve got a wye fitting on the trunk line to add a hide-a-hose in the future if I want, and a branch line capped for a future port in my enclosed porch. I may eventually add a regular low-voltage inlet to the garage wall, and run a riser down for some sweep inlets in the kitchen and main bathroom, but it’s good enough for now, and everything works.
Amazed by the power of the unit and the suction. Still need to vent it outside (it’s right next to an exterior wall) and finish up the dedicated circuit, but it’s tested and works as desired.
