Filter Queen Brush Roller
michvacguy
Michigan
Hi Everyone!
Are there any ways to adjust the brush roller on a Filter Queen Majestic to get it to extend past the bottom plate to be a bit more aggressive on carpeting? Or, are there any after-market rollers with longer bristles?
Thanks.
Your brush roll should be able to be adjusted one time. When you remove the rug plate, notice the rubber end caps. Rotate the end caps 180 degrees and it should raise your brush roll so that you get more bristles sticking out when you replace the rug plate. If it has already been adjusted once, you will need a new brush roll. They do make aftermarket brush rolls to fit or you can stick with the genuine.
PR-21
Bud
