Eureka Princess Canister TV Commercial
Thanks Paul, once again! Your post showing Jimmy's Princess advertised in 1975 has given me the definite year of its manufacture: 1975. The brandname label is a retro touch using the font style from the early 1960's.
Looking at the pics of Jimmy's blue Princess, I noticed another indicator suggesting a 1970's date for the cleaner: the lack of slots on the necks of all three steel wands. In the 1950's and 1960's, Eureka's steel wands all had slotted perforations around the neck to help the user know when the wands were inserted sufficiently to give a secure connection. In the 1970's at some point, these slots disappeared and the wands had no perforations at all.
Eureka
Photo 1,Reply 18--Is very close to mine but shows the rubber cover on metal handle.This was one of many features that could be added or subtracted from the same body.
"Did Eureka change hose fitting-?"--50s & 60s hose had 2 grooves that matched 2 spring wires on vac,later hose pushed and locked with 2 buttons to release.This would wear as vac was pulled.Then hose pushed and turned to lock with 1 push button to release.
"vinyl hose"--Many vacs including Eureka and GE used newer hoses in the late 50s.Some were featured in Dayco Rubber Co ads.Many of these seemed to break and tear even in normal use.By early 60s some vac companies seem to have gone back to braided hoses.
"slots-on wands"--These later wands had rolled edge and small square bumps indented to improve fit and release.
I have a very nice 60s blue Eureka upright that would be a good companion to the Princess when I have time.
Metallic Gold Princess
Posted by APM Studios at Brainson.org.
https://www.brainson.org/episode/2024/05/14/how-do-vacuums-work
The unusual rear nameplate gives me pause that the cleaner may have been repainted and a color copy of the original affixed afterward.
Some time ago, I found a newspaper ad featuring a chrome Princess, so then again maybe this one just a company anomaly.
Turns out there was, in fact, a metallic gold Princes model 705 that was marketed in 1967 (see the Lagoon Blue/Platinum Blue 705-B in reply #14), but the model in the photo is the same design as the 737 with a wide handle, lid striations, and Cordaway.
No other ads for a metallic gold Princess have surfaced, and besides I think I see a bit of paint on the handle in the canister in the photo; so I have my doubts about it being original.
  • 1967 Jun 8 EUGENE REGISTER-GUARD - Weisfeld Jewelers Limited Edition Eureka Golden Princess Mo...png
    497.1 KB
  • 1967 Jun 8 EUGENE REGISTER-GUARD - Weisfield's Jewelers Limited Edition Eureka Golden Princess...png
    127 KB
  • 1967 Dec 18 THE BULLETIN - Eureka Golden Princess 705 for Christmas at Weisfield's.png
    595.6 KB
  • 1968 May 16 ST. PETERSBURG TIMES - Eureka Model-Type 737-ARG - in green.png
    250.3 KB
I think that unusual gold Princess 737 is actually from a display at the Mid Missouri Vacuum Store and Museum. The museum is run by Vacuumland member Dysonman, I think. He would definitely know the story behind that Eureka.
I know I've seen that TV ad before, but I'd never noticed the internal tool tray. That's definitely a neat touch and a better alternative, IMO, to the external tool caddy that so often gets broken up on those machines. I've owned a total of three Eureka canisters, of which I presently have two, and none of them has had a completely intact tool caddy. They're just too fragile and vulnerable.
I was never a fan of canister vacuums that stored their attachments inside the dustbag compartment. No where did I ever see a warning label to remove the tools or tool tray before turning on the vacuum. Any residual dirt, lint and dust left on the bristles of the tools could easily get sucked off and clog the premotor filter if they were left in the dust bag compartment while using the vacuum. Besides Eureka, I remember that some canisters sold by Singer, Kenmore and Hoover stored some of the attachments in the dustbag compartment. Too me, this would never be good for the motor, and would even make the tools dirty as they could get covered in any fine dust leaking out from the hose connection or the bag itself.
If it were part of the former museum it may be toast now, because he just posted on another thread that he tossed the ones that weren't picked up by collectors. Btw, I'm not positive that it is/was a 737; only that it looks like it. It probably is, but then again there are a few 700s for which I was unable to locate ads.
